> How many additional quarts of oil do you need?, External oil cooler question.
Craigers17
post Jan 29 2020, 05:48 PM
So this is probably a stupid question, but I'm assuming that if you choose to run an external oil cooler, you have to add at least another quart of oil due to the additional volume in the lines and cooler coils.
I'm also guessing that the additional volume varies depending upon the cooler location. So if a stock 2.0 - 4 takes roughly 3.5-4 quarts, how much additional oil is required? Let's assume a rear mounted unit.
Or...is it as simple as fill up the cooler and lines, install, and then fill as normal until it matches the dipstick fill line?
Any advice/ridicule is welcome. Thanks.
VaccaRabite
post Jan 29 2020, 08:10 PM
En Garde!
Yeah mine with a rear mounted aux cooler, lines and a tuna can is about 5 quarts instead of 4 if everything drains out.
But that said, the oil cooler never completely drains so its more like 4.5.
Zach
- Lo-Fi Version Time is now: 15th September 2026 - 01:26 AM
