| LotusJoe |
Feb 21 2012, 06:25 PM
Europa Twink Driver ![]() ![]() Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
I'm installing the rear blower motor. Mine only as one outlet. I'm assuming this is because it had air conditioning.
The parts book only list one blower motor, but it has two outlets, although the parts number on my blower matches the one in the parts book. (IMG:style_emoticons/default/confused24.gif) 914 rubber shows a blower with two outlets as well, but different from the parts book?? ![]() |
| Rob-O |
Jan 29 2020, 08:58 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,321 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region
dumb question but I'll ask b/c its cold outside and i want heat. The blower motor mounted on the firewall isn't coming on. but when turn on the "fan" switch I can hear a blower coming from under the dash. I assume both blower motors should activate? There are two actuators. To turn on the rear fan, pull up on the switch/lever with the red plastic top, that is located behind the shifter. thx...tried that. Not working. Time to trouble shoot It’s a pretty basic switch. Usually it’s just got some corrosion and isn’t making a good ground where the handle is attached to the body of the car. |
LotusJoe Rear Heater Blower Motor Feb 21 2012, 06:25 PM
SLITS The early cars had a two outlet blower which Porsc... Feb 21 2012, 06:35 PM
LotusJoe
The early cars had a two outlet blower which Pors... Feb 21 2012, 07:01 PM
McMark There were three stock setups for the auxiliary he... Feb 21 2012, 07:21 PM
Prospectfarms
...Also, worth clarifying for some silent readers... Feb 21 2012, 07:30 PM
brainf18 dumb question but I'll ask b/c its cold outsid... Jan 29 2020, 07:57 PM
Jett
dumb question but I'll ask b/c its cold outsi... Jan 29 2020, 08:07 PM
brainf18
dumb question but I'll ask b/c its cold outs... Jan 29 2020, 08:29 PM
rhodyguy You have to set the dash controls so the fresh air... Jan 29 2020, 08:58 PM
maf914
You have to set the dash controls so the fresh ai... Jan 30 2020, 07:41 AM
SirAndy It’s a pretty basic switch. Usually it’s just... Jan 29 2020, 09:37 PM
johnhora Here's some pics of the early engine mount bra... Jan 30 2020, 11:58 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th November 2026 - 05:04 PM |
