| brcacti |
Jan 30 2020, 05:18 PM
1974 914 1.8 ![]() ![]() ![]() Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Hello, my experienced VW mechanic put in my xr700 electronic ignition he said it runs well but said my bad fumes may be a FI cold start valve sticking. Would love to get mechanics input from this forum on that, is it easy or hard to put in, can a non mechanic put that in and how much about does it cost for one?
Thank you |
| dr914@autoatlanta.com |
Jan 30 2020, 05:49 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,236 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Probably not the valve, could be the air flow meter flap sticking, the air gap not set on the electronic ignition or the timing not correct, or low compression due to bad valve adjust and or a bad head temp sensor
. The cold start valve on the 1.8 fires at 60 degrees or colde Hello, my experienced VW mechanic put in my xr700 electronic ignition he said it runs well but said my bad fumes may be a FI cold start valve sticking. Would love to get mechanics input from this forum on that, is it easy or hard to put in, can a non mechanic put that in and how much about does it cost for one? Thank you |
brcacti FI cold start valve need advise Jan 30 2020, 05:18 PM
TheCabinetmaker Just disconnect the hoses and attach a double ende... Jan 30 2020, 05:28 PM
TheCabinetmaker Where do you smell the gas? Jan 30 2020, 05:34 PM
Rand Your profile says you are in Phoenix. I doubt your... Jan 30 2020, 05:37 PM
brcacti
Probably not the valve, could be the air flow met... Jan 31 2020, 05:02 PM
ndfrigi
[quote name='dr914@autoatlanta.com' post='2781781... Jan 31 2020, 06:19 PM
Rand Sounds like the doc is in ljet mode. Is this Djet? Jan 30 2020, 06:09 PM
brcacti
Sounds like the doc is in ljet mode. Is this Djet... Jan 30 2020, 06:27 PM
dr914@autoatlanta.com the initial subject was designated as 74 1.8, so I... Jan 31 2020, 10:30 AM
brcacti
the initial subject was designated as 74 1.8, so ... Jan 31 2020, 01:11 PM
jcd914
[quote name='dr914@autoatlanta.com' post='2781934... Jan 31 2020, 01:21 PM
ndfrigi
[quote name='dr914@autoatlanta.com' post='2781934... Jan 31 2020, 01:25 PM
pete000 Bad fumes? could it just be a bad charcoal filter ... Jan 30 2020, 06:41 PM
brcacti Seems to me to be running very rich saw gas fumes ... Jan 30 2020, 06:52 PM
rjames Are all of the FI components original and/or corre... Jan 30 2020, 07:01 PM
brcacti
Are all of the FI components original and/or corr... Jan 30 2020, 07:28 PM
Rand If you are seeing "fumes" out the exhaus... Jan 30 2020, 08:48 PM
TheCabinetmaker Pull all the spark plugs and check for one that... Jan 31 2020, 08:33 AM
brcacti Hello, here is a pic of my cold start valve I assu... Jan 31 2020, 02:17 PM
ndfrigi RE: FI cold start valve need advise Jan 31 2020, 02:36 PM
ndfrigi Here is the pic again to reply on your personal me... Jan 31 2020, 07:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 02:17 PM |
