| brcacti |
Jan 30 2020, 05:18 PM
1974 914 1.8 ![]() ![]() ![]() Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Hello, my experienced VW mechanic put in my xr700 electronic ignition he said it runs well but said my bad fumes may be a FI cold start valve sticking. Would love to get mechanics input from this forum on that, is it easy or hard to put in, can a non mechanic put that in and how much about does it cost for one?
Thank you |
| TheCabinetmaker |
Jan 31 2020, 08:33 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,377 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Pull all the spark plugs and check for one that's wet, or very black.
brcacti FI cold start valve need advise Jan 30 2020, 05:18 PM
TheCabinetmaker Just disconnect the hoses and attach a double ende... Jan 30 2020, 05:28 PM
TheCabinetmaker Where do you smell the gas? Jan 30 2020, 05:34 PM
Rand Your profile says you are in Phoenix. I doubt your... Jan 30 2020, 05:37 PM
dr914@autoatlanta.com Probably not the valve, could be the air flow mete... Jan 30 2020, 05:49 PM
brcacti
Probably not the valve, could be the air flow met... Jan 31 2020, 05:02 PM
ndfrigi
[quote name='dr914@autoatlanta.com' post='2781781... Jan 31 2020, 06:19 PM
Rand Sounds like the doc is in ljet mode. Is this Djet? Jan 30 2020, 06:09 PM
brcacti
Sounds like the doc is in ljet mode. Is this Djet... Jan 30 2020, 06:27 PM
dr914@autoatlanta.com the initial subject was designated as 74 1.8, so I... Jan 31 2020, 10:30 AM
brcacti
the initial subject was designated as 74 1.8, so ... Jan 31 2020, 01:11 PM
jcd914
[quote name='dr914@autoatlanta.com' post='2781934... Jan 31 2020, 01:21 PM
ndfrigi
[quote name='dr914@autoatlanta.com' post='2781934... Jan 31 2020, 01:25 PM
pete000 Bad fumes? could it just be a bad charcoal filter ... Jan 30 2020, 06:41 PM
brcacti Seems to me to be running very rich saw gas fumes ... Jan 30 2020, 06:52 PM
rjames Are all of the FI components original and/or corre... Jan 30 2020, 07:01 PM
brcacti
Are all of the FI components original and/or corr... Jan 30 2020, 07:28 PM
Rand If you are seeing "fumes" out the exhaus... Jan 30 2020, 08:48 PM
brcacti Hello, here is a pic of my cold start valve I assu... Jan 31 2020, 02:17 PM
ndfrigi RE: FI cold start valve need advise Jan 31 2020, 02:36 PM
ndfrigi Here is the pic again to reply on your personal me... Jan 31 2020, 07:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 02:17 PM |
