> FI cold start valve need advise, 1974 914 1.8
brcacti
post Jan 30 2020, 05:18 PM
Hello, my experienced VW mechanic put in my xr700 electronic ignition he said it runs well but said my bad fumes may be a FI cold start valve sticking. Would love to get mechanics input from this forum on that, is it easy or hard to put in, can a non mechanic put that in and how much about does it cost for one?
Thank you
Rand
post Jan 30 2020, 06:09 PM
Cross Member
Sounds like the doc is in ljet mode. Is this Djet?
dr914@autoatlanta.com
post Jan 31 2020, 10:30 AM
the initial subject was designated as 74 1.8, so I figured that was for which fuel injection system he needed advice. The main problem calling rich running is the sticking air flow meter flap caused by lean backfire
QUOTE(Rand @ Jan 30 2020, 05:09 PM) *
brcacti   FI cold start valve need advise   Jan 30 2020, 05:18 PM
TheCabinetmaker   Just disconnect the hoses and attach a double ende...   Jan 30 2020, 05:28 PM
TheCabinetmaker   Where do you smell the gas?   Jan 30 2020, 05:34 PM
Rand   Your profile says you are in Phoenix. I doubt your...   Jan 30 2020, 05:37 PM
dr914@autoatlanta.com   Probably not the valve, could be the air flow mete...   Jan 30 2020, 05:49 PM
brcacti   Probably not the valve, could be the air flow met...   Jan 31 2020, 05:02 PM
ndfrigi   [quote name='dr914@autoatlanta.com' post='2781781...   Jan 31 2020, 06:19 PM
Rand   Sounds like the doc is in ljet mode. Is this Djet?   Jan 30 2020, 06:09 PM
brcacti   Sounds like the doc is in ljet mode. Is this Djet...   Jan 30 2020, 06:27 PM
dr914@autoatlanta.com   the initial subject was designated as 74 1.8, so I...   Jan 31 2020, 10:30 AM
brcacti   the initial subject was designated as 74 1.8, so ...   Jan 31 2020, 01:11 PM
jcd914   [quote name='dr914@autoatlanta.com' post='2781934...   Jan 31 2020, 01:21 PM
ndfrigi   [quote name='dr914@autoatlanta.com' post='2781934...   Jan 31 2020, 01:25 PM
pete000   Bad fumes? could it just be a bad charcoal filter ...   Jan 30 2020, 06:41 PM
brcacti   Seems to me to be running very rich saw gas fumes ...   Jan 30 2020, 06:52 PM
rjames   Are all of the FI components original and/or corre...   Jan 30 2020, 07:01 PM
brcacti   Are all of the FI components original and/or corr...   Jan 30 2020, 07:28 PM
Rand   If you are seeing "fumes" out the exhaus...   Jan 30 2020, 08:48 PM
TheCabinetmaker   Pull all the spark plugs and check for one that...   Jan 31 2020, 08:33 AM
brcacti   Hello, here is a pic of my cold start valve I assu...   Jan 31 2020, 02:17 PM
ndfrigi   RE: FI cold start valve need advise   Jan 31 2020, 02:36 PM
ndfrigi   Here is the pic again to reply on your personal me...   Jan 31 2020, 07:05 PM
- Lo-Fi Version Time is now: 30th April 2026 - 02:16 PM
