brcacti |
1974 914 1.8 ![]() ![]() ![]() Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region ![]() |
dlee6204 |
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 ![]() |
If your idle speed has changed, it maybe the ignition timing base adjustment has advanced. The throttle blade adjustment did not change. (IMG:style_emoticons/default/agree.gif) That would be the first thing I would verify. Make sure your timing was set correctly after the change. I would then operate the throttle body manually with the cable disconnected. Check it see if it is closing all the way. If not, then your throttle body needs works. If so, then I would mess with idle adjustment. And of course if your throttle cable is too tight it can have an effect as well. |
Lo-Fi Version | Time is now: 17th July 2025 - 05:04 AM |
