| djm914-6 |
May 22 2003, 07:07 AM
Happiness is: Getting on the road ![]() ![]() ![]() Group: Members Posts: 1,864 Joined: 6-February 03 From: Burlington MA Member No.: 248 Region Association: None |
On my ride to work this morning, I noticed my car wasn't idling as high as usual while sitting at lights. I also noticed that I was grinding gears much more than ususal. When I got to work, I stepped on the clutch with the car in gear and the rpms went to 500 or below. When I put the car in nutral, the rpms went back up to 900 plus. So, I figure the clutch isn't fully disengaging.
I have seen articles on how to adjust a tail shifters clutch cable, but I need a real basic, "what to do" description. Like, which way to turn the nuts, does the cable need to be tightened or loosened, etc. This is a new cable with less than a few hundred miles on it. Thanks, |
| need4speed |
May 22 2003, 12:28 PM
Member ![]() ![]() Group: Members Posts: 339 Joined: 11-April 03 From: Arroyo Grande, CA Member No.: 564 |
Yeah, it's fun when you're at a light, clutch down, brakes off, and the car still starts to roll forward. Time to get under there and get dirty.
Thing is - it could be that your NEW clutch cable did a little stretching. So logically, you want to turn the wingnut to shorten the overall effective length. If you make it too short, it'll slip, and then you'll know to back it off. |
djm914-6 Clutch adjustment help May 22 2003, 07:07 AM
72Signal914 Mine was doing just about the same thing and my cl... May 22 2003, 07:43 AM
meursault No wingnut. Listen not to the ghia man. Get down t... May 22 2003, 12:56 PM
silver six Dave,
While it could be as simple as a clutch adj... May 22 2003, 02:18 PM
need4speed ![]() ![]() |
Lo-Fi Version | Time is now: 19th March 2026 - 11:12 PM |
