> Clutch adjustment help, looking for a really good explanation
djm914-6
post May 22 2003, 07:07 AM
Happiness is: Getting on the road
On my ride to work this morning, I noticed my car wasn't idling as high as usual while sitting at lights. I also noticed that I was grinding gears much more than ususal. When I got to work, I stepped on the clutch with the car in gear and the rpms went to 500 or below. When I put the car in nutral, the rpms went back up to 900 plus. So, I figure the clutch isn't fully disengaging.
I have seen articles on how to adjust a tail shifters clutch cable, but I need a real basic, "what to do" description. Like, which way to turn the nuts, does the cable need to be tightened or loosened, etc. This is a new cable with less than a few hundred miles on it.
Thanks,
meursault
post May 22 2003, 12:56 PM
Idjit Savant
No wingnut. Listen not to the ghia man. Get down there with a pliers and an 11mm wrench. hold the end of the cable with the pliers and turn the nut clockwise until the cable seems a little taut. Get up or have an assistant check the freeplay at the pedal. Adjust the cable down there to your heart's content until your pedal has about an inch of freeplay, meaning that you press down the pedal about an inch before you meet a change in resistance.
djm914-6   Clutch adjustment help   May 22 2003, 07:07 AM
72Signal914   Mine was doing just about the same thing and my cl...   May 22 2003, 07:43 AM
need4speed   Yeah, it's fun when you're at a light, clu...   May 22 2003, 12:28 PM
meursault   No wingnut. Listen not to the ghia man. Get down t...   May 22 2003, 12:56 PM
silver six   Dave, While it could be as simple as a clutch adj...   May 22 2003, 02:18 PM
need4speed
- Lo-Fi Version Time is now: 19th March 2026 - 11:11 PM
