| sbruzek |
Feb 5 2020, 03:38 PM
Newbie ![]() Group: Members Posts: 35 Joined: 17-January 12 From: United States Member No.: 14,024 Region Association: Upper MidWest |
My 1973 2.0 has a very, very high idle. 30000, even higher to 50000, if you disconnect vacuum hose at aux air looking for a leak, or stuck. Only thing that lowers idles down a little, to 25000 or so, is disconnecting vacuum line to the pressure sensor. Pulling off any vacuum lines and plugging them don’t lower the idle any.
This started after I replaced one leaking fuel injector. I did put on new seals with the new and old injector on that side. All the vacuum lines are new and vacuum is very good and strong on all vacuum lines. Pressure sensor holds a vacuum fine. Any suggestions? I did set timing to red mark per manual as I noticed distributor moved a bit when working. It was a bit loose so I set timing and tighten distributor down good. But had to set timing at 25000 rpm as I could not get it any lower at correct timing marks. I do have an oil leak at the oil cooler seals that is getting worse. Is that a vacuum leak? Starts up great and runs good just have a crazy high idle. Steve B |
| dr914@autoatlanta.com |
Feb 6 2020, 09:31 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,220 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
you have knocked off or broken a vacuum line or fitting, or the throttle is stuck. Removing the pressure sensor line just richens it up excessively drowning the engine and lowering the idle.
It is a simple problem though quote name='sbruzek' date='Feb 5 2020, 02:38 PM' post='2783404'] My 1973 2.0 has a very, very high idle. 30000, even higher to 50000, if you disconnect vacuum hose at aux air looking for a leak, or stuck. Only thing that lowers idles down a little, to 25000 or so, is disconnecting vacuum line to the pressure sensor. Pulling off any vacuum lines and plugging them don’t lower the idle any. This started after I replaced one leaking fuel injector. I did put on new seals with the new and old injector on that side. All the vacuum lines are new and vacuum is very good and strong on all vacuum lines. Pressure sensor holds a vacuum fine. Any suggestions? I did set timing to red mark per manual as I noticed distributor moved a bit when working. It was a bit loose so I set timing and tighten distributor down good. But had to set timing at 25000 rpm as I could not get it any lower at correct timing marks. I do have an oil leak at the oil cooler seals that is getting worse. Is that a vacuum leak? Starts up great and runs good just have a crazy high idle. Steve B [/quote] |
| ctc911ctc |
Feb 6 2020, 10:11 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,287 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
Are those number in metric units? Seems that there is an extra zero??? (IMG:style_emoticons/default/poke.gif)
(IMG:style_emoticons/default/smile.gif) [quote name='dr914@autoatlanta.com' date='Feb 6 2020, 10:31 AM' post='2783568'] you have knocked off or broken a vacuum line or fitting, or the throttle is stuck. Removing the pressure sensor line just richens it up excessively drowning the engine and lowering the idle. It is a simple problem though quote name='sbruzek' date='Feb 5 2020, 02:38 PM' post='2783404'] My 1973 2.0 has a very, very high idle. 30000, even higher to 50000, if you disconnect vacuum hose at aux air looking for a leak, or stuck. Only thing that lowers idles down a little, to 25000 or so, is disconnecting vacuum line to the pressure sensor. Pulling off any vacuum lines and plugging them don’t lower the idle any. This started after I replaced one leaking fuel injector. I did put on new seals with the new and old injector on that side. All the vacuum lines are new and vacuum is very good and strong on all vacuum lines. Pressure sensor holds a vacuum fine. Any suggestions? I did set timing to red mark per manual as I noticed distributor moved a bit when working. It was a bit loose so I set timing and tighten distributor down good. But had to set timing at 25000 rpm as I could not get it any lower at correct timing marks. I do have an oil leak at the oil cooler seals that is getting worse. Is that a vacuum leak? Starts up great and runs good just have a crazy high idle. Steve B [/quote] [/quote] |
sbruzek Very high idle Feb 5 2020, 03:38 PM
BeatNavy Most likely you still have a vacuum leak somewhere... Feb 5 2020, 04:12 PM
sbruzek Wow! I’ve been in the garage since your re... Feb 5 2020, 07:04 PM
JamesM
I think the new seals were a bit harder that the... Feb 5 2020, 11:43 PM
BeatNavy :beer2: Feb 5 2020, 07:22 PM
TheCabinetmaker More than likely, one of the injectors was cockeye... Feb 6 2020, 06:42 AM
JawjaPorsche My manifold air intake hoses looked good but after... Feb 6 2020, 06:56 AM
sbruzek
Are those number in metric units? Seems that ther... Feb 6 2020, 12:20 PM
sbruzek Thanx to all for your help and suggestions.
Id... Feb 6 2020, 12:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 04:57 AM |
