| sbruzek |
Feb 5 2020, 03:38 PM
Newbie ![]() Group: Members Posts: 35 Joined: 17-January 12 From: United States Member No.: 14,024 Region Association: Upper MidWest |
My 1973 2.0 has a very, very high idle. 30000, even higher to 50000, if you disconnect vacuum hose at aux air looking for a leak, or stuck. Only thing that lowers idles down a little, to 25000 or so, is disconnecting vacuum line to the pressure sensor. Pulling off any vacuum lines and plugging them don’t lower the idle any.
This started after I replaced one leaking fuel injector. I did put on new seals with the new and old injector on that side. All the vacuum lines are new and vacuum is very good and strong on all vacuum lines. Pressure sensor holds a vacuum fine. Any suggestions? I did set timing to red mark per manual as I noticed distributor moved a bit when working. It was a bit loose so I set timing and tighten distributor down good. But had to set timing at 25000 rpm as I could not get it any lower at correct timing marks. I do have an oil leak at the oil cooler seals that is getting worse. Is that a vacuum leak? Starts up great and runs good just have a crazy high idle. Steve B |
| sbruzek |
Feb 6 2020, 12:25 PM
Thanx to all for your help and suggestions.
Idle is fixed now. It was due to a leak at one of the fuel injectors. Could have been I just had one of them in crooked or new seal did not seat well. Just glad it’s fixed. : (IMG:style_emoticons/default/piratenanner.gif) Thanx again to all. Steve |
sbruzek Very high idle Feb 5 2020, 03:38 PM
BeatNavy Most likely you still have a vacuum leak somewhere... Feb 5 2020, 04:12 PM
sbruzek Wow! I’ve been in the garage since your re... Feb 5 2020, 07:04 PM
JamesM
I think the new seals were a bit harder that the... Feb 5 2020, 11:43 PM
BeatNavy :beer2: Feb 5 2020, 07:22 PM
TheCabinetmaker More than likely, one of the injectors was cockeye... Feb 6 2020, 06:42 AM
JawjaPorsche My manifold air intake hoses looked good but after... Feb 6 2020, 06:56 AM
dr914@autoatlanta.com you have knocked off or broken a vacuum line or fi... Feb 6 2020, 09:31 AM
ctc911ctc Are those number in metric units? Seems that there... Feb 6 2020, 10:11 AM
sbruzek
Are those number in metric units? Seems that ther... Feb 6 2020, 12:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 04:58 AM |
