Show off your gauges!, post some pictures and vote on what you think looks best, gauges or no gauges |
DRPHIL914 |
Feb 7 2020, 07:16 AM
Dr. Phil Group: Members Posts: 5,769 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
so I had an idea about this while searching for picture of gauges and placement and so on, and then on the thread about Classic AC's new center console AC unit, one member's biggest issue was just hating the center console and the "useless" gauges and distaste in general for the center console and it taking up space.
I can appreciate the simplicity of no console, but I do like the look of a nice clean console, and while I agree I really don't need a clock, I do like having functional gauges like my volt meter, Lambda gauge, and the new CHT temp gauge I just installed. AND even though I am fairly tall and have long legs I do not have an issue with it taking up room , in fact I kind of like resting my leg up against it on a long drive. But I digress! I would like to see how others have dealt with and oriented their gauges on the cluster, in the dash or center console. I have seen a few other pictures here and there but my search didn't pull up a thread that had put together a majority of those various approaches. I personally had to source an aftermarket center console because the original one ordered with the car's Appearance group package had been removed years ago. and now that I have customized this, I am also wanting to install AC in a way to not put the under dash unit it and would consider this Center console unit, BUT I have to figure out where else I would put the A/F meter gauge and the CHT and Volt meter at the very least I would want to retain those somewhere, not on the A-pillar, maybe in dash? Hmmmm--- post away!! Phil |
Chris914n6 |
Feb 7 2020, 07:06 PM
Jackstands are my life. Group: Members Posts: 3,341 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
We have a dummy lite for volts so the gauge is kinda mute... it's charging or it's not.
The other 2 more useful gauges can go in a bracket mounted in place of the ash tray. |
DickSteinkamp |
Feb 7 2020, 07:22 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
We have a dummy lite for volts so the gauge is kinda mute... it's charging or it's not. The other 2 more useful gauges can go in a bracket mounted in place of the ash tray. I'm not sure what "2 more useful gauges" are. A clock? (IMG:style_emoticons/default/wacko.gif) An oil pressure gauge? Not unless you keep the low OP light also. The light is going to tell you far better of a failure (unless you keep your eyes glued to the gauges instead of the road). I think it is OK to have a whole bevy of gauges. Nice to know stuff. But that doesn't work too well in our 914s. The Getty dash is the best solution if you HAVE to have them. A big box in the middle of the car....not so much. |
Lo-Fi Version | Time is now: 17th June 2024 - 12:25 PM |
