> LED headlight load for Fogs. ?
bandjoey
post Feb 15 2020, 01:01 PM
bandjoey
Three years ago when LED headlights started being offered for 914 I bought a set from Vintage lighting. This week The driver side headlight started blowing a fuse every time the lights were turned on. I switched out to a sealed beam light and it works fine. So that LED bulb must’ve gone bad. I looked at the $99 replacement bulb set at 914 rubber and there’s a statement that says if you have fog lights be sure and add a load to make them work. So if I go that route how do I add a load? I am also considering buying the new complete LED 7” headlight set that says plug and play as an entire unit. Will I run into the same problem with that unit?
Mikey914
post Feb 16 2020, 03:53 AM
The rubber man
Should be a quick swap since you have the housing already mounted.
Do check the prong socket, I have seen some real crappy ones. Technically you would think that as long as the prongs are all on tight you’d be ok, but maybe it’s grounded out. Should be easy to see.
Mark
- Lo-Fi Version Time is now: 16th July 2025 - 03:51 PM
