porsche 914 2.0 full set powdercoated engine tin, $800 porsche 914 2.0 full set powdercoated engine tin |
volkaholic |
Feb 16 2020, 07:21 PM
Newbie Group: Members Posts: 1 Joined: 31-July 15 From: Ohio Member No.: 19,015 Region Association: None |
$800 This is a real 1975-1976 Porsche 914 2 liter engine tin. It has the 3 bolt cylinder heads and the angled spark plugs that only came on this engine. CYLINDER TINS FIT THESE HEADS ONLY! The spark plug holes are in a different place than all other type iv heads! Top cylinder sheetmetal is specific for this engine!
This engine has all sheet metal to go into a Porsche 914, including the fan shroud + the firewall tin You get everything show, 25 parts + all new engine tins screws to install it all. All parts are OEM used German except the #3 cylinder surround which someone made, it fits, it works, i'm fine with it. SOME PEOPLE HAVE CLAIMED THIS IS NOT 914, WELL WHAT CAN I SAY, THE ENGINE CODE ON THE BLOCK IS 75-76 914, IT HAD FI, IT HAS 3 BOLT HEADS, IT HAS ANGLED SPARK PLUGS! now, is it possible that some one put 914 engine in a bus, a 411 or a 912, and then mixed in some other tins? yeah sure, so maybe some of the tin is different, but you got to have these cylinder tins for these heads. The following work has been done. good used, tested, german thermostat included new thermostat cable included fan included alternator included new fan belt included all engine tin blasted and powdercoated satin black cast fan shroud blasted and powdercoated agate gray - to match Porsche 356 fan shrouds price is $800 plus shipping, i use paypal Attached thumbnail(s) |
bdstone914 |
Feb 16 2020, 09:11 PM
bdstone914 Group: Members Posts: 4,535 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
That is not a complete tin set. Also the passenger top tin has been chopped for AC. Most of the pieces in the bottom row and the one in the upper right corner are not 914 parts.
You are missing the long two piece tin that goes under and in front of the fan housing. Warm air guides and one J tube are missing. |
Lo-Fi Version | Time is now: 7th June 2024 - 04:51 AM |
