| motorvated |
Feb 16 2020, 07:30 PM
Member ![]() ![]() Group: Members Posts: 282 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
My engine came with the flywheel detached so I'm not sure what goes where. Haynes manual mentions a felt washer and the exploded view from Autoatlanta shows two "sealing rings". My flywheel has a pilot bearing and my gasket kit has a new plate that goes on the outboard side of the flywheel under the five bolts. After installing the correct crankshaft shims and the new rear main seal, what goes between it and the flywheel and how do they fit? If the felt washer is one of the two "sealing rings" depicted in the exploded view, where/how is it fitted and is it saturated with oil first or left dry. Is the other "sealing ring" an o-ring and where/how is it fitted. Thanks.
| davep |
Feb 18 2020, 09:13 PM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,382 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Um, NO. The felt washer is supposed to retain oil to lubricate the pilot bearing behind it. Has the pilot bearing been replaced???
The big washer and the 5 bolts are really considered to be one time use items. I have reused the bolts in the past but one time the bolts came loose as did the flywheel, so the resulting damage was extensive. Bolts are cheap insurance; besides the are supposed to be stretch bolts, thus the one time use. Some mechanics use Loctite on the threads to prevent loosening. |
| motorvated |
Feb 19 2020, 07:32 AM
Um, NO. The felt washer is supposed to retain oil to lubricate the pilot bearing behind it. Has the pilot bearing been replaced??? The big washer and the 5 bolts are really considered to be one time use items. I have reused the bolts in the past but one time the bolts came loose as did the flywheel, so the resulting damage was extensive. Bolts are cheap insurance; besides the are supposed to be stretch bolts, thus the one time use. Some mechanics use Loctite on the threads to prevent loosening. The new flywheel that I am installing has a good pilot bearing in it already. I have a new big washer and have ordered the felt washer. If the washer arrives dry, are you saying that I should oil the pilot bearing and the felt washer prior to installing it? No grease in the pilot bearing, just oil? |
motorvated What Goes Between Rear Main Seal and Flywheel? Feb 16 2020, 07:30 PM
motorvated
My engine came with the flywheel detached so I... Feb 17 2020, 02:11 PM
ndfrigi This might help you.
http://www.914world.com/bbs... Feb 17 2020, 02:27 PM
Mark Henry Use grease on the pilot bearing, just a small dab.... Feb 19 2020, 08:50 AM
dr914@autoatlanta.com rear main, flywheel o ring, needle bearing, felt w... Feb 19 2020, 11:03 AM![]() ![]() |
Lo-Fi Version | Time is now: 13th November 2026 - 06:09 PM |
