How do you adjust your windows?, Mine let a "little" water in... |
ChrisReale |
Dec 10 2004, 01:00 AM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
Ok, so a lot of water gets in when it rains. Prolly because there is a gap between the window and the rubber seal. How do you adjust your side windows so that there is no gap?
SGB |
Dec 10 2004, 09:52 AM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
Replacing the fuzzy strips inside is easy and helps tighten up the window. There are several adjustment locations; a screw on the winder part of the regulator limits upward traval. There is a screw through the bottom of the door, near the rear, to adjust rake in and out. Make sure the screw at the top of the track near the door handle is tight, too.
Lo-Fi Version | Time is now: 7th June 2024 - 03:33 PM |
