theleschyouknow |
Senior Member ![]() ![]() ![]() Group: Members Posts: 524 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None ![]() |
I am cleaning up some axles and re-lubing cv’s
first axle, first cv popped off the half shaft with just a few good tugs per cuddyk’s youtube how to first axle, second cv cannot get the spider and cage off the axle started with tugging and pretty soon the balls and outer cylinder were in my hands but spider and cage still on half shaft moved to hammer & punch working around the back side perimeter of conical washer up against the spider got some movement but slow and seemed to stop with about a 16th of an inch of the half shaft grooves still proud of the outboard side of the spider I was spraying with wd-40 intermittently all the while next borrowed a slide hammer and puller plate from o’reilly maybe got a little more progress but still see grooves proud of the outboard side of the was spider I’ve soaked it over night with wd-40 and will hit it again with the puller/slide hammer this afternoon Any other suggestions? l don’t have a torch here but I’d be hesitant to use one on the spider anyway TIA (IMG:style_emoticons/default/beerchug.gif) cjl |
Lo-Fi Version | Time is now: 9th July 2025 - 01:18 PM |
