theleschyouknow |
Senior Member ![]() ![]() ![]() Group: Members Posts: 524 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None ![]() |
I am cleaning up some axles and re-lubing cv’s
first axle, first cv popped off the half shaft with just a few good tugs per cuddyk’s youtube how to first axle, second cv cannot get the spider and cage off the axle started with tugging and pretty soon the balls and outer cylinder were in my hands but spider and cage still on half shaft moved to hammer & punch working around the back side perimeter of conical washer up against the spider got some movement but slow and seemed to stop with about a 16th of an inch of the half shaft grooves still proud of the outboard side of the spider I was spraying with wd-40 intermittently all the while next borrowed a slide hammer and puller plate from o’reilly maybe got a little more progress but still see grooves proud of the outboard side of the was spider I’ve soaked it over night with wd-40 and will hit it again with the puller/slide hammer this afternoon Any other suggestions? l don’t have a torch here but I’d be hesitant to use one on the spider anyway TIA (IMG:style_emoticons/default/beerchug.gif) cjl |
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,266 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
This should not have happened unless somehow the spline is galled.
Post aome pics of the cv races. I rcommend new cv.s and axles at this point. Once done you will probably never have to mess with them again. |
theleschyouknow |
This should not have happened unless somehow the spline is galled. Post aome pics of the cv races. I rcommend new cv.s and axles at this point. Once done you will probably never have to mess with them again. here’s some pics of the first one l got cleaned up and the stuck one looks pretty rough but l really got these to clean up and have as spares so no harm done really but would like to get them cleaned up ![]() ![]() ![]() |
914_teener |
This should not have happened unless somehow the spline is galled. Post aome pics of the cv races. I rcommend new cv.s and axles at this point. Once done you will probably never have to mess with them again. here’s some pics of the first one l got cleaned up and the stuck one looks pretty rough but l really got these to clean up and have as spares so no harm done really but would like to get them cleaned up ![]() ![]() ![]() Replace as George suggests. Not worth your time. |
Lo-Fi Version | Time is now: 9th July 2025 - 01:41 PM |
