Oh oh...., Wheel stud issue |
jim_hoyland |
Feb 26 2020, 06:04 PM
Get that VIN ? Group: Members Posts: 9,321 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
As I was rotating my wheels, I see one front wheel stud is shorter. I shot pics before putting the wheel on.
IIRC, this stud had some movement several years ago. Not sure how to proceed. The billet hubs are mounted onto the rotors; these are the one Brad Roberts sold awhile back. Calipers show how much thread is showing @Mueller Attached image(s) |
Root_Werks |
Feb 26 2020, 06:07 PM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Look like threaded studs, double-nut and turn it out. Probably held in place with thread locker.
SirAndy |
Feb 26 2020, 07:03 PM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Look like threaded studs, double-nut and turn it out. Probably held in place with thread locker. (IMG:style_emoticons/default/agree.gif) Take two out and compare the length, if you are lucky, this one just ended up deeper than the others. Otherwise replace it with a longer one to match the others. (IMG:style_emoticons/default/popcorn[1].gif) |
jim_hoyland |
Feb 26 2020, 07:13 PM
They started out the same length. I noticed this one stud had worked its way down when changing the wheels previously.
Can't remember if the studs are threaded inside and screwed in or had splines and pressed in. Double nuts; I'll pick up tomorrow, what size will I need ? Look like threaded studs, double-nut and turn it out. Probably held in place with thread locker. (IMG:style_emoticons/default/agree.gif) Take two out and compare the length, if you are lucky, this one just ended up deeper than the others. Otherwise replace it with a longer one to match the others. (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 11th June 2024 - 10:09 AM |
