Pops out of 3rd Gear at Decel, SOLVED: swapped transmissions |
poorsche914 |
Feb 26 2020, 11:35 AM
T4 Supercharged Group: Members Posts: 3,091 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
Shift Linkage: new bushings at console, firewall, and coupler.
Goes into all other gears but third seems "soft" instead of "solid" engagement. Upon deceleration (and randomly if not holding the lever), pops out of 3rd gear. I haven't had a chance to check fluid level yet... plug is being difficult (IMG:style_emoticons/default/dry.gif) Do I need to keep fine tuning the linkage adjustment or is third gear probably shot? Thanks! (IMG:style_emoticons/default/driving.gif) |
Mikey914 |
Feb 26 2020, 09:15 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Did you do the mounts on the engine to the bar. many folks miss those. If the outside edge ones were toast, they probably were not far behind.
Hate to ask the question again, but they are less obvious. |
poorsche914 |
Feb 26 2020, 09:48 PM
Did you do the mounts on the engine to the bar. many folks miss those. If the outside edge ones were toast, they probably were not far behind. Hate to ask the question again, but they are less obvious. Yes, the motor to bar mounts are fairly new. Transmission mounts are in good condition. Outer bar mounts are just a bolt, washers and nut. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:55 AM |
