QUOTE(ClayPerrine @ Feb 26 2020, 01:00 PM)
Adjust the linkage while in neutral. Loosen the clamp bolt and push the gear lever forward till it moves about 1/4 inch or so at the coupler and tighten it back up.
QUOTE(dr914@autoatlanta.com @ Feb 26 2020, 01:19 PM)
try adjusting a bit, shortening the linkage, and then if that does not work, hold it into gear for awhile and see if it starts going in again
I have made the adjustment as suggested but perhaps I need just a bit more
Headed to the garage shortly. Will give the "hold in gear" option a try.
This gearbox has basically been dormant for 25 years.
Thanks!
EDIT: adjusted it 1/4" and then even more but eventually lost ability to hit 4th.
Drove it a couple miles holding in 3rd but it still wants to pop out :-(
1st and 5th click right in and stay put.
