Pops out of 3rd Gear at Decel, SOLVED: swapped transmissions |
poorsche914 |
Feb 26 2020, 11:35 AM
T4 Supercharged Group: Members Posts: 3,087 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
Shift Linkage: new bushings at console, firewall, and coupler.
Goes into all other gears but third seems "soft" instead of "solid" engagement. Upon deceleration (and randomly if not holding the lever), pops out of 3rd gear. I haven't had a chance to check fluid level yet... plug is being difficult (IMG:style_emoticons/default/dry.gif) Do I need to keep fine tuning the linkage adjustment or is third gear probably shot? Thanks! (IMG:style_emoticons/default/driving.gif) |
ClayPerrine |
Feb 26 2020, 12:00 PM
Life's been good to me so far..... Group: Admin Posts: 15,442 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Shift Linkage: new bushings at console, firewall, and coupler. Goes into all other gears but third seems "soft" instead of "solid" engagement. Upon deceleration (and randomly if not holding the lever), pops out of 3rd gear. I haven't had a chance to check fluid level yet... plug is being difficult (IMG:style_emoticons/default/dry.gif) Do I need to keep fine tuning the linkage adjustment or is third gear probably shot? Thanks! (IMG:style_emoticons/default/driving.gif) Adjust the linkage while in neutral. Loosen the clamp bolt and push the gear lever forward till it moves about 1/4 inch or so at the coupler and tighten it back up. That may help, no guarantees. But it is worth a try before you spend the money on a rebuilt gearbox. |
dr914@autoatlanta.com |
Feb 26 2020, 12:19 PM
914 Guru Group: Members Posts: 7,838 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
try adjusting a bit, shortening the linkage, and then if that does not work, hold it into gear for awhile and see if it starts going in again
Shift Linkage: new bushings at console, firewall, and coupler. Goes into all other gears but third seems "soft" instead of "solid" engagement. Upon deceleration (and randomly if not holding the lever), pops out of 3rd gear. I haven't had a chance to check fluid level yet... plug is being difficult (IMG:style_emoticons/default/dry.gif) Do I need to keep fine tuning the linkage adjustment or is third gear probably shot? Thanks! (IMG:style_emoticons/default/driving.gif) |
poorsche914 |
Feb 26 2020, 12:28 PM
Adjust the linkage while in neutral. Loosen the clamp bolt and push the gear lever forward till it moves about 1/4 inch or so at the coupler and tighten it back up. try adjusting a bit, shortening the linkage, and then if that does not work, hold it into gear for awhile and see if it starts going in again I have made the adjustment as suggested but perhaps I need just a bit more (IMG:style_emoticons/default/confused24.gif) Headed to the garage shortly. Will give the "hold in gear" option a try. This gearbox has basically been dormant for 25 years. Thanks! EDIT: adjusted it 1/4" and then even more but eventually lost ability to hit 4th. Drove it a couple miles holding in 3rd but it still wants to pop out :-( 1st and 5th click right in and stay put. (IMG:style_emoticons/default/driving.gif) |
ClayPerrine |
Feb 26 2020, 02:09 PM
Sorry.. you are down to replacing the gearbox. If you are desperate to drive it, then swap it out with the one in the creamsicle, the send it to Dr. Evil and get it rebuilt.
DRPHIL914 |
Feb 26 2020, 02:21 PM
Worn synchros and dog teeth but, what about fluid levels? When I bought my car it was doing that , so after a while I was told check fluid- it had about 29% of the required gear oil!!! So a full clean flush and new fluid helped and got me thru a couple years until I went to transmission cloning and rebuilt it .
poorsche914 |
Feb 26 2020, 02:39 PM
... If you are desperate to drive it, then swap it out with the one in the creamsicle... Yeah... will do that if a fluid change doesn't help.... so after a while I was told check fluid- it had about 29% of the required gear oil!!! So a full clean flush and new fluid helped and got me thru a couple years until I went to transmission cloning and rebuilt it. Checking the fluid level is my next step but I have to get the plug off first!(IMG:style_emoticons/default/driving.gif) |
theer |
Feb 26 2020, 02:55 PM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
Make sure to take the FILL plug out first.. so that you know you can refill before you empty all the fluid!
Mmm hmmm - ask me how I know that. |
poorsche914 |
Feb 26 2020, 03:02 PM
Make sure to take the FILL plug out first.. so that you know you can refill before you empty all the fluid! Mmm hmmm - ask me how I know that. Excellent advice that I have seen mentioned many times so, yeah... top plug first (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/driving.gif) |
Mikey914 |
Feb 26 2020, 07:21 PM
The rubber man Group: Members Posts: 12,657 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Check the trans and motor mounts. Decel will twist the geometry of the linkage. It may be providing enough twist to to just that.
just an idea |
poorsche914 |
Feb 26 2020, 07:44 PM
Check the trans and motor mounts. Decel will twist the geometry of the linkage. It may be providing enough twist to to just that. just an idea Thanks, Mark. Motor mounts are fairly new as I replaced them less than a year ago after one had disintegrated which lead to shifting issues (IMG:style_emoticons/default/blink.gif) Trans mounts are good as well. Have drained the gear oil and bought new. Will fill and test again tomorrow. (IMG:style_emoticons/default/driving.gif) |
Mikey914 |
Feb 26 2020, 09:15 PM
Did you do the mounts on the engine to the bar. many folks miss those. If the outside edge ones were toast, they probably were not far behind.
Hate to ask the question again, but they are less obvious. |
poorsche914 |
Feb 26 2020, 09:48 PM
Did you do the mounts on the engine to the bar. many folks miss those. If the outside edge ones were toast, they probably were not far behind. Hate to ask the question again, but they are less obvious. Yes, the motor to bar mounts are fairly new. Transmission mounts are in good condition. Outer bar mounts are just a bolt, washers and nut. (IMG:style_emoticons/default/confused24.gif) |
Mikey914 |
Feb 26 2020, 11:26 PM
Just thinking that 3rd is an odd gear to be worn to that extent. At least not without significant wear on the lower gearing.
ndfrigi |
Feb 27 2020, 12:36 AM
how about shifting it to 3rd gear manually by the console and see if u can move/run the car from 3rd gear.
Tdskip |
Feb 27 2020, 04:10 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
porschetub |
Feb 28 2020, 01:31 PM
I always presumed they pop out of gear when the load comes on after shifting not on deceleration (IMG:style_emoticons/default/confused24.gif) .
mrholland2 |
Feb 28 2020, 02:08 PM
Senior Member Group: Members Posts: 750 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
Did you do the mounts on the engine to the bar. many folks miss those. If the outside edge ones were toast, they probably were not far behind. Hate to ask the question again, but they are less obvious. Yes, the motor to bar mounts are fairly new. Transmission mounts are in good condition. Outer bar mounts are just a bolt, washers and nut. (IMG:style_emoticons/default/confused24.gif) Are all the weird little pieces in the linkage good? is there play at the console? That limits your adjustment tolerances. |
poorsche914 |
Feb 28 2020, 04:24 PM
Are all the weird little pieces in the linkage good? is there play at the console? That limits your adjustment tolerances. Yes, all the bushings are new or in good condition. I finally got fluid changed but haven't had a chance to test drive due to a dead battery (IMG:style_emoticons/default/dry.gif) Question: Looking at the rear console shift bushing... which way should it be inserted? From the front or from the rear? It is currently from the front and I am thinking there is some interference on the rearward side. (IMG:style_emoticons/default/driving.gif) |
BENBRO02 |
Feb 28 2020, 04:41 PM
Member Group: Members Posts: 480 Joined: 6-March 15 From: Nokesville, Virginia Member No.: 18,493 Region Association: MidAtlantic Region |
Adjust the linkage while in neutral. Loosen the clamp bolt and push the gear lever forward till it moves about 1/4 inch or so at the coupler and tighten it back up. try adjusting a bit, shortening the linkage, and then if that does not work, hold it into gear for awhile and see if it starts going in again I have made the adjustment as suggested but perhaps I need just a bit more (IMG:style_emoticons/default/confused24.gif) Headed to the garage shortly. Will give the "hold in gear" option a try. This gearbox has basically been dormant for 25 years. Thanks! EDIT: adjusted it 1/4" and then even more but eventually lost ability to hit 4th. Drove it a couple miles holding in 3rd but it still wants to pop out :-( 1st and 5th click right in and stay put. (IMG:style_emoticons/default/driving.gif) I had the exact same problem when I put a dormant car on the road. I thought the gearbox was ready for a rebuild but my mechanic adjusted the linkage and it now works fine. Don't assume you need a rebuild until all else is exhausted. If I remember correctly, mine was far worse when I first started driving it. It gradually became better but took a linkage adjustment to fix it completely. |
Lo-Fi Version | Time is now: 7th May 2024 - 11:19 PM |
