Pops out of 3rd Gear at Decel, SOLVED: swapped transmissions |
poorsche914 |
Feb 26 2020, 11:35 AM
T4 Supercharged Group: Members Posts: 3,091 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
Shift Linkage: new bushings at console, firewall, and coupler.
Goes into all other gears but third seems "soft" instead of "solid" engagement. Upon deceleration (and randomly if not holding the lever), pops out of 3rd gear. I haven't had a chance to check fluid level yet... plug is being difficult (IMG:style_emoticons/default/dry.gif) Do I need to keep fine tuning the linkage adjustment or is third gear probably shot? Thanks! (IMG:style_emoticons/default/driving.gif) |
dr914@autoatlanta.com |
Feb 26 2020, 12:19 PM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
try adjusting a bit, shortening the linkage, and then if that does not work, hold it into gear for awhile and see if it starts going in again
Shift Linkage: new bushings at console, firewall, and coupler. Goes into all other gears but third seems "soft" instead of "solid" engagement. Upon deceleration (and randomly if not holding the lever), pops out of 3rd gear. I haven't had a chance to check fluid level yet... plug is being difficult (IMG:style_emoticons/default/dry.gif) Do I need to keep fine tuning the linkage adjustment or is third gear probably shot? Thanks! (IMG:style_emoticons/default/driving.gif) |
poorsche914 |
Feb 26 2020, 12:28 PM
Adjust the linkage while in neutral. Loosen the clamp bolt and push the gear lever forward till it moves about 1/4 inch or so at the coupler and tighten it back up. try adjusting a bit, shortening the linkage, and then if that does not work, hold it into gear for awhile and see if it starts going in again I have made the adjustment as suggested but perhaps I need just a bit more (IMG:style_emoticons/default/confused24.gif) Headed to the garage shortly. Will give the "hold in gear" option a try. This gearbox has basically been dormant for 25 years. Thanks! EDIT: adjusted it 1/4" and then even more but eventually lost ability to hit 4th. Drove it a couple miles holding in 3rd but it still wants to pop out :-( 1st and 5th click right in and stay put. (IMG:style_emoticons/default/driving.gif) |
BENBRO02 |
Feb 28 2020, 04:41 PM
Member Group: Members Posts: 483 Joined: 6-March 15 From: Nokesville, Virginia Member No.: 18,493 Region Association: MidAtlantic Region |
Adjust the linkage while in neutral. Loosen the clamp bolt and push the gear lever forward till it moves about 1/4 inch or so at the coupler and tighten it back up. try adjusting a bit, shortening the linkage, and then if that does not work, hold it into gear for awhile and see if it starts going in again I have made the adjustment as suggested but perhaps I need just a bit more (IMG:style_emoticons/default/confused24.gif) Headed to the garage shortly. Will give the "hold in gear" option a try. This gearbox has basically been dormant for 25 years. Thanks! EDIT: adjusted it 1/4" and then even more but eventually lost ability to hit 4th. Drove it a couple miles holding in 3rd but it still wants to pop out :-( 1st and 5th click right in and stay put. (IMG:style_emoticons/default/driving.gif) I had the exact same problem when I put a dormant car on the road. I thought the gearbox was ready for a rebuild but my mechanic adjusted the linkage and it now works fine. Don't assume you need a rebuild until all else is exhausted. If I remember correctly, mine was far worse when I first started driving it. It gradually became better but took a linkage adjustment to fix it completely. |
Lo-Fi Version | Time is now: 11th June 2024 - 04:46 AM |
