Pops out of 3rd Gear at Decel, SOLVED: swapped transmissions |
poorsche914 |
Feb 26 2020, 11:35 AM
T4 Supercharged Group: Members Posts: 3,091 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
Shift Linkage: new bushings at console, firewall, and coupler.
Goes into all other gears but third seems "soft" instead of "solid" engagement. Upon deceleration (and randomly if not holding the lever), pops out of 3rd gear. I haven't had a chance to check fluid level yet... plug is being difficult (IMG:style_emoticons/default/dry.gif) Do I need to keep fine tuning the linkage adjustment or is third gear probably shot? Thanks! (IMG:style_emoticons/default/driving.gif) |
Mikey914 |
Feb 26 2020, 09:15 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Did you do the mounts on the engine to the bar. many folks miss those. If the outside edge ones were toast, they probably were not far behind.
Hate to ask the question again, but they are less obvious. |
poorsche914 |
Feb 26 2020, 09:48 PM
Did you do the mounts on the engine to the bar. many folks miss those. If the outside edge ones were toast, they probably were not far behind. Hate to ask the question again, but they are less obvious. Yes, the motor to bar mounts are fairly new. Transmission mounts are in good condition. Outer bar mounts are just a bolt, washers and nut. (IMG:style_emoticons/default/confused24.gif) |
mrholland2 |
Feb 28 2020, 02:08 PM
Senior Member Group: Members Posts: 753 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
Did you do the mounts on the engine to the bar. many folks miss those. If the outside edge ones were toast, they probably were not far behind. Hate to ask the question again, but they are less obvious. Yes, the motor to bar mounts are fairly new. Transmission mounts are in good condition. Outer bar mounts are just a bolt, washers and nut. (IMG:style_emoticons/default/confused24.gif) Are all the weird little pieces in the linkage good? is there play at the console? That limits your adjustment tolerances. |
poorsche914 |
Feb 28 2020, 04:24 PM
Are all the weird little pieces in the linkage good? is there play at the console? That limits your adjustment tolerances. Yes, all the bushings are new or in good condition. I finally got fluid changed but haven't had a chance to test drive due to a dead battery (IMG:style_emoticons/default/dry.gif) Question: Looking at the rear console shift bushing... which way should it be inserted? From the front or from the rear? It is currently from the front and I am thinking there is some interference on the rearward side. (IMG:style_emoticons/default/driving.gif) |
Tdskip |
Feb 28 2020, 08:16 PM
Are all the weird little pieces in the linkage good? is there play at the console? That limits your adjustment tolerances. Yes, all the bushings are new or in good condition. I finally got fluid changed but haven't had a chance to test drive due to a dead battery (IMG:style_emoticons/default/dry.gif) Question: Looking at the rear console shift bushing... which way should it be inserted? From the front or from the rear? It is currently from the front and I am thinking there is some interference on the rearward side. (IMG:style_emoticons/default/driving.gif) Check out second page for picture http://www.914world.com/bbs2/index.php?sho...42046&st=20 |
Lo-Fi Version | Time is now: 10th June 2024 - 09:07 PM |
