Should I move my fuel pump? |
Lilchopshop |
Mar 2 2020, 07:25 AM
Member Group: Members Posts: 75 Joined: 17-February 20 From: New York Member No.: 23,932 Region Association: North East States |
I've been working hard on my newly-acquired 73 2.0. Thanks to everyone on this site for all the inspiration and motivation! Currently have engine out, engine compartment stripped, interior stripped, gas tank out. Since the car has been sitting for 30+ years, i decided I would replace all the fuel lines. I plan to buy a complete stainless fuel line kit from Tangerine. In the state I'm at currently, it would be an ideal time to re-locate the fuel pump. I plan to keep the D-jet injection. Should I move the fuel pump to under the tank? Are there any down sides to this? What pump should I get?
Thanks in advance, Aaron |
Root_Werks |
Mar 2 2020, 11:49 AM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
I'll probably get whacked for saying this, but yes, I'd move it to the front and swap over to a 2 port fuel pump. The 3 ports are period correct for 73', but hard to come by. You're moving the pump anyway, might as well convert to the 75-76 configuration.
Lilchopshop |
Mar 2 2020, 01:21 PM
I'll probably get whacked for saying this, but yes, I'd move it to the front and swap over to a 2 port fuel pump. The 3 ports are period correct for 73', but hard to come by. You're moving the pump anyway, might as well convert to the 75-76 configuration. Forgive my ignorance, but what is the functional difference between a 3-port, early pump and a 2-port, late pump. Will the 2-port pump work seamlessly with my D-jet? I'm putting functionality over period-correctness on this car. |
Root_Werks |
Mar 2 2020, 01:24 PM
I'll probably get whacked for saying this, but yes, I'd move it to the front and swap over to a 2 port fuel pump. The 3 ports are period correct for 73', but hard to come by. You're moving the pump anyway, might as well convert to the 75-76 configuration. Forgive my ignorance, but what is the functional difference between a 3-port, early pump and a 2-port, late pump. Will the 2-port pump work seamlessly with my D-jet? I'm putting functionality over period-correctness on this car. No functional difference, it'll work fine and is simple to plumb the lines. Look how a 75'-76' 2.0 914 is plumbed in any repair manual. Follow that and you're good to go. |
Lo-Fi Version | Time is now: 7th June 2024 - 05:44 PM |
