Mystery, Bolts? |
Mystery, Bolts? |
shane |
Mar 8 2020, 07:11 PM
Member Group: Members Posts: 355 Joined: 12-February 13 Member No.: 15,518 Region Association: None |
KevinW |
Mar 8 2020, 07:54 PM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
They mount on the bucket to adjust the amount of travel. It is a stop adjustment.
SirAndy |
Mar 8 2020, 10:07 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
They mount on the bucket to adjust the amount of travel. It is a stop adjustment. No, please don't use them as a "stop" to adjust travel! The bolts are only supposed to just barely touch the tabs on the headlight bucket when the headlights are in the fully open position to prevent the light from vibrating when open. If you remove those bolts you'll see that the headlights will still stop just fine in the open position, there is no "stop" needed at all. (IMG:style_emoticons/default/shades.gif) |
lierofox |
Mar 9 2020, 03:12 AM
Member Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California |
They mount on the bucket to adjust the amount of travel. It is a stop adjustment. No, please don't use them as a "stop" to adjust travel! The bolts are only supposed to just barely touch the tabs on the headlight bucket when the headlights are in the fully open position to prevent the light from vibrating when open. If you remove those bolts you'll see that the headlights will still stop just fine in the open position, there is no "stop" needed at all. (IMG:style_emoticons/default/shades.gif) Almost sounds like something you'd send a newbie out to grab. Grab me a pack of piston return springs. Need a tube of elbow grease. Go in and ask for a headlight antivibe bolt. |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:01 PM |
