Brake Fluid Flood at Pedal Cluster |
CoronaMike |
Mar 22 2020, 03:09 PM
Member Group: Members Posts: 152 Joined: 11-February 19 From: Maryville, TN Member No.: 22,868 Region Association: South East States |
Hi y'all,
So, in the final stages of getting my car back on the road and was bleeding my brakes. Then i started seeing my footprints around the garage and I couldn't figure out why... turns out the carpet was soaked with brake fluid! Does anyone know what's going on - AND - Is there any way to fix this withOUT taking the pedal cluster out? (one of my least favorite things in life to do) Or should I just bite the bullet - pull the pedals and the master cylinder...(my second least favorite). Thanks!!! mike |
Mikey914 |
Mar 23 2020, 02:18 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Thanks for the props guys.
Bleeding the MC can be an issue with a pressure bleeder if you crank up the pressure. The best way is by vacuum https://www.harborfreight.com/Brake-Bleeder...nRoCIK4QAvD_BwE |
Lo-Fi Version | Time is now: 10th June 2024 - 12:57 AM |
