Rear Struts and Springs, Original and Busted! |
ctc911ctc |
Mar 24 2020, 07:08 AM
Senior Member Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
'74 2.0L
Found this one in RI and have resurrected it from a 40 year nap over the past 1.5 years - could not have done this without the teeeners, thank you! My son noticed that the cars stance had changed. I went under the car and found that the original strut has blown a gasket and is leaking - perhaps now it is NOT moving correctly, etc. QUESTION For a non-performance-but-good-ride what would you recommend as a replacement? I am guessing that I would replace the struts and the springs as a complete assembly? (IMG:style_emoticons/default/confused24.gif) Thank you Teeners (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) |
mepstein |
Mar 24 2020, 08:58 AM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Most of the time the springs are shot. Save all the pieces when you take apart your old assembly. There are a couple parts that get reused. Bruce Stone often has good used shocks if you are on a budget. Bilstein is often the "go to" and are available from many sources. You usually want the HD as the sports are usually to stiff for road and better for the track. It's hard to find the springs that fit but I believe 914rubber now has replacements.
If you decide to do the front struts, you can replace the inserts by dropping the top of the strut from the car without having to remove the entire assembly. |
Lo-Fi Version | Time is now: 10th June 2024 - 03:51 PM |
