> Jacking point damage?
Biggles
post Mar 25 2020, 10:00 AM
Region Association: England
I've noticed that the front jacking points on my car aren't level, and wondered if they've gone up as the car has been lifted - thoughts? It all seems solid.
post Mar 25 2020, 10:15 AM
Resident German
They are crooked because those aren't jacking points!
There is noting solid on the other side, using them as jacking points means you are deforming your floorpan.
Biggles
post Mar 25 2020, 10:29 AM
QUOTE(SirAndy @ Mar 25 2020, 04:15 PM) *
Ok not good. Thanks. I had used a reference on the world referencing round 'donuts' that were safe to jack on - evidently not! What purpose do those areas serve ?
So where is good to Jack up the car?
dr914@autoatlanta.com
post Mar 25 2020, 10:37 AM
jack under the engine mounting bar, or the front cross member, these are to rest jack stands with pieces of plywood to cushion the jack stand from the donut
QUOTE(Biggles @ Mar 25 2020, 09:29 AM) *
Biggles
post Mar 25 2020, 11:13 AM
Cheers George. No engine mounting bar. It's a 6. I've been jacking on the rear donuts or on the trailing arm pick up points at the rear - no good?
QUOTE(dr914@autoatlanta.com @ Mar 25 2020, 04:37 PM) *
Biggles   Jacking point damage?   Mar 25 2020, 10:00 AM
SirAndy   They are crooked because those aren't jacking ...   Mar 25 2020, 10:15 AM
Biggles   They are crooked because those aren't jacking...   Mar 25 2020, 10:29 AM
dr914@autoatlanta.com   jack under the engine mounting bar, or the front c...   Mar 25 2020, 10:37 AM
Biggles   Cheers George. No engine mounting bar. It's a ...   Mar 25 2020, 11:13 AM
bkrantz   They are crooked because those aren't jacking...   Mar 25 2020, 08:29 PM
914e   They are crooked because those aren't jackin...   Mar 25 2020, 09:32 PM
bretth   I thought all four doughnuts were for jacking up/s...   Mar 25 2020, 11:05 AM
SirAndy   The donuts were used to suspend the cars on the as...   Mar 25 2020, 11:17 AM
Biggles   The donuts were used to suspend the cars on the a...   Mar 25 2020, 11:18 AM
ctc911ctc   SirAndy! MORE OF THESE FACTORY PICTURES PLEAS...   Mar 25 2020, 04:47 PM
SirAndy   And if you check the location of the donuts in the...   Mar 25 2020, 11:19 AM
kroelofsen   And if you check the location of the donuts in th...   Mar 25 2020, 02:12 PM
wes   I saved this year’s back from here.   Mar 25 2020, 11:58 AM
gandalf_025   You can see the point on the floor ,in front of th...   Mar 25 2020, 03:14 PM
rgalla9146   You can see the point on the floor ,in front of t...   Mar 25 2020, 04:34 PM
mbseto   So aside from accuracy, there's no reason to r...   Mar 25 2020, 04:59 PM
bretth   I think if it was designed to hang the whole car o...   Mar 25 2020, 06:13 PM
drem914   If those are not where we are suppose to jack the ...   Mar 25 2020, 06:49 PM
cuddy_k   If those are not where we are suppose to jack the...   Mar 26 2020, 12:10 AM
drem914   If those are not where we are suppose to jack th...   Mar 26 2020, 10:02 PM
SO.O.C914er   I agree these are the jack points if they are not ...   Mar 25 2020, 07:25 PM
Biggles   Based on the responses, the fact the rear donuts /...   Mar 26 2020, 03:25 AM
euro911   RE: Jacking point damage?   Jul 6 2020, 11:49 AM
euro911   Here's a site that has pix & videos ... ht...   Jul 6 2020, 01:30 PM
Retroracer   Donut jacking: interesting reading for me. Early ...   Jul 6 2020, 05:44 PM
Cairo94507   Jesus.....what is the best way to lift a 914 w/o d...   Jul 6 2020, 05:50 PM
euro911   Jesus.....what is the best way to lift a 914 w/o d...   Jul 6 2020, 11:38 PM
mepstein   Jesus.....what is the best way to lift a 914 w/o ...   Jul 7 2020, 06:17 AM
MM1   Sir Andy, Is it possible for you to elucidate my ...   Jul 6 2020, 06:34 PM
Cairo94507   OK- I have a few hockey pucks and several other li...   Jul 7 2020, 06:32 AM
MM1   Thanks, Gents! Mark - so when jacking the fro...   Jul 7 2020, 09:31 AM
mepstein   Thanks, Gents! Mark - so when jacking the fr...   Jul 7 2020, 10:45 AM
MM1   Thanks, Gents! Mark - so when jacking the f...   Jul 8 2020, 09:52 AM
- Lo-Fi Version Time is now: 22nd September 2026 - 10:17 AM
