Rear Rotor Removal, rusted stuck? Not Anymore!, Two Screws? |
cassmcentee |
Mar 27 2020, 02:00 PM
Member Group: Members Posts: 180 Joined: 12-July 18 From: Squaw Valley, CA Member No.: 22,304 Region Association: Central California |
Is the rear rotor held on to the hub by these two screws at this point?
I have Soaked/Heated/Hammered but the screws aren't budging. Am I missing something here??? My guess is they are rusted in place... I have a torch with a rosebud tip, didn't heat the rotor to red thinking that I could possibly warp the rotor...so I just went close to red... Do I have to drill these and then tap them out? Thank You, Cass |
porschetub |
Mar 27 2020, 02:19 PM
Advanced Member Group: Members Posts: 4,705 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Put a punch which is about the same size as the recessed hole and hit very hard with a hammer,then use an impact wrench the fits the slot properly,if this fails center punch (dead centre) the screws and drill them till the heads are gone.
Once the disk is off the remains of the screws should wind out with ease,good luck. |
Lo-Fi Version | Time is now: 7th June 2024 - 09:52 PM |
