Rear Rotor Removal, rusted stuck? Not Anymore!, Two Screws? |
cassmcentee |
Mar 27 2020, 02:00 PM
Member Group: Members Posts: 180 Joined: 12-July 18 From: Squaw Valley, CA Member No.: 22,304 Region Association: Central California |
Is the rear rotor held on to the hub by these two screws at this point?
I have Soaked/Heated/Hammered but the screws aren't budging. Am I missing something here??? My guess is they are rusted in place... I have a torch with a rosebud tip, didn't heat the rotor to red thinking that I could possibly warp the rotor...so I just went close to red... Do I have to drill these and then tap them out? Thank You, Cass |
IronHillRestorations |
Mar 27 2020, 07:41 PM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I'd probably keep soaking it with Seafoam Deep Creep or 1 part ATF with 1 part acetone, those are the best penetrating fluids I've found. I'd also take a screwdriver and hammer and tap straight in on the screws, like you're driving it in, several times a day. It might take a couple days but the fluid will work it's way in. If you don't want to wait then take Garold's advice and drill off the heads of the screws.
The rotors have two threaded holes for screwing an M6 bolt in to pop them off the hub. |
Lo-Fi Version | Time is now: 1st June 2024 - 11:09 AM |
