Rear Rotor Removal, rusted stuck? Not Anymore!, Two Screws? |
cassmcentee |
Mar 27 2020, 02:00 PM
Member Group: Members Posts: 180 Joined: 12-July 18 From: Squaw Valley, CA Member No.: 22,304 Region Association: Central California |
Is the rear rotor held on to the hub by these two screws at this point?
I have Soaked/Heated/Hammered but the screws aren't budging. Am I missing something here??? My guess is they are rusted in place... I have a torch with a rosebud tip, didn't heat the rotor to red thinking that I could possibly warp the rotor...so I just went close to red... Do I have to drill these and then tap them out? Thank You, Cass |
Bmw635 |
Mar 27 2020, 02:47 PM
Member Group: Members Posts: 66 Joined: 19-February 20 From: OC, CA Member No.: 23,943 Region Association: Southern California |
Could try this impact driver. Hammer the handle and the bit will twist in direction you want while pushing the tip in to prevent rounding.
bkrantz |
Mar 27 2020, 08:38 PM
914 Guru Group: Members Posts: 7,802 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Porschef |
Mar 28 2020, 06:07 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Could try this impact driver. Hammer the handle and the bit will twist in direction you want while pushing the tip in to prevent rounding. This is my favorite and always successful tool, that I keep around just for that job. (IMG:style_emoticons/default/agree.gif) Last time I used this was for exactly the same purpose. Clean the slot thoroughly, make sure the tip fits properly. Heat, spray in some PB Blaster, Liquid Wrench, or penetrant of your choice, (yes, the ATF/acetone works well, been using it for years, but you need to shake frequently to keep it mixed), repeat, seat the impact square and whack it but good with a lumpy hammer. It’ll come off, and provide you with a sense of accomplishment... (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 04:15 AM |
