> Brain Trust Needed - 2L Refresh
yeahmag
post Mar 28 2020, 11:01 AM
This might be long...
My current combo runs great, but I've been sitting on a set of Finch heads from Len Hoffman for years. There is no racing right now, so it seems like a good time. Here is the current combo:
2056cc
Stock Rods
Stock 2L heads (match ported)
86a Cam
9.5:1
I got a set of JE pistons in another deal (brand new, 96mm) and they appear to be stroker pistons. By my calculations I'd only need a 5.294" rod to counter the reduced pin height and am planning on a 5.325" rod or longer. Should be good either way there.
Now for the big problem. The Finch heads have a 50cc step-cut chamber. I like to run a tight deck (.04") and that combo would put me at 10:1. To get to the 9.5:1 I've been running I'd need to run almost .06" deck height.
So three questions.
1. Can the 86a handle 10:1 on 91 pump gas with proper tuning?
2. Is it better to run a loose deck and keep it at 9.5:1?
3. Put a 2cc (or larger) dish in the piston tops to keep a tight deck and lower the CR to 9.5:1 which I know works?
Thanks!
-Aaron
injunmort
post Apr 1 2020, 07:47 AM
how are you changing rods without splitting the case?
- Lo-Fi Version Time is now: 15th July 2025 - 10:23 AM
