| thelogo |
Mar 29 2020, 11:33 AM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
This is not for camping or shelter purpose
But im trying to build a mobile dog grooming salon Ive ruled out new and extremly expensive sprinters So that leave 1st and 2nd gen Here is one i made a offer on https://orangecounty.craigslist.org/cto/d/o...7094720538.html Are these going to be a maintence nightmare Or a strong work vehicle Poease advise (IMG:style_emoticons/default/wub.gif) and feel free to be long winded |
| 914forme |
Apr 1 2020, 06:52 PM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,899 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
it is missing at least one digit on the ODO reading.
The V6 of that age has a couple of issues. Oil cooler seals leak, oil cooler is in the V of the engine and you have to remove the entire intake, and fuel system ha to be puled to get to it. For two seals, and problem solved. Fuel injector seals will blow out, and produce a leak, which creates this nice black carbon structure, which is a pain to clean up. Seat needs to be cleaned, and then the copper O needs replaced. Oil and engine blow by is sucked out of the valve cover into an area right infront of the turbo. That seal leaks, and it fills the turbo, and Intercooler with oil over a long period of time. Seal at the turbo inlet also leaks. And should be replaced, easy to do when you do the filter change. Maintenance Oil changes cost me about $180 in parts to do it right 10 quarts of oil. Trans oil changes where also about $280, every 40K Fuel filters every 20K Air filters needed to be checked at oil changes, mine had an affinity to suck all the small insects to large insects off the interstate. And the wold need replace 9 time out of 10. As the pressure built do to restrictive filters the oil draw off the vent system would increase. Oh it burned 2 Quarts of oil over the 10,000 mile interval, majority of it was from the breather system. I had a Mann Hummel recovery unit on it, I would get about 1.5 quarts out of the system. Positives, engine ran great, I had a tune done on it, and it would get 27 MPG, never noticed anything I had behind it. I would still be driving it, if I did not find a deal on two BMWs. |
thelogo Its about to go off topic .sprinter van owners chime in Mar 29 2020, 11:33 AM
JOEPROPER You may be happier with a Ford Transit... I do so... Mar 29 2020, 11:47 AM
thelogo
You may be happier with a Ford Transit... I do s... Mar 29 2020, 11:50 AM
Bmw635 Thought about using trailers? Replacing tow vehicl... Mar 29 2020, 12:12 PM
thelogo
Thought about using trailers? Replacing tow vehic... Mar 29 2020, 12:16 PM
Montreal914 what about Ram Promaster van? Front wheel drive, l... Mar 29 2020, 12:21 PM
thelogo
what about Ram Promaster van? Front wheel drive, ... Mar 29 2020, 12:31 PM
Craigers17 This one looks like a keeper. Mar 29 2020, 04:30 PM
thelogo
That will be the ... Mar 29 2020, 06:06 PM
Craigers17
That will be the... Mar 29 2020, 06:18 PM
thelogo
[quote name='thelogo' post='2798975' date='Mar 29... Mar 29 2020, 07:07 PM
Larmo63 RE: Its about to go off topic .sprinter van owners chime in Mar 29 2020, 09:53 PM
thelogo https://losangeles.craigslist.org/lac/cto/d...7097... Mar 29 2020, 10:33 PM
UROpartsman Have also heard that Sprinters are really expensiv... Mar 30 2020, 12:19 PM
thelogo
Have also heard that Sprinters are really expensi... Mar 30 2020, 01:19 PM
BigFour1973
Have also heard that Sprinters are really expens... Mar 30 2020, 01:48 PM
porschetub
Have also heard that Sprinters are really expensi... Mar 30 2020, 09:16 PM
thelogo
Have also heard that Sprinters are really expens... Mar 30 2020, 09:41 PM
Superhawk996 The main problem with any of the Sprinters (regard... Mar 30 2020, 02:00 PM
thelogo
The main problem with any of the Sprinters (regar... Mar 30 2020, 08:54 PM
PanelBilly Ford has 84 month 0 interest financing right now w... Mar 30 2020, 03:14 PM
thelogo
Ford has 84 month 0 interest financing right now ... Mar 30 2020, 08:46 PM
Ford has 84 month 0 interest financing right now... Mar 30 2020, 09:12 PM
thelogo
[quote name='thelogo' post='2799316' date='Mar 30... Mar 30 2020, 11:57 PM
Superhawk996
Are you fuckin nuts ....
Ive always bought al... Mar 31 2020, 08:01 AM
JRust I had a 2004 & a 2005 2500 sprinter vans with ... Mar 30 2020, 03:29 PM
RickS Unless you are catering to the rich and famous whe... Mar 30 2020, 09:14 PM
thelogo
Unless you are catering to the rich and famous wh... Mar 30 2020, 09:24 PM
SteveL
New high roof cargo van ....$ thats a big n... Mar 31 2020, 06:54 AM
JOEPROPER Many smart men and women in business use other peo... Mar 31 2020, 07:31 AM
andys Ok folks, read the low/no interest ads, and they g... Mar 31 2020, 09:01 AM
Ok folks, read the low/no interest ads, and they ... Mar 31 2020, 09:37 AM
JOEPROPER
Ok folks, read the low/no interest ads, and they... Mar 31 2020, 09:42 AM
thelogo
Ok folks, read the low/no interest ads, and they ... Mar 31 2020, 09:42 AM
Superhawk996
Ok folks, read the low/no interest ads, and they... Mar 31 2020, 11:00 AM
R1200rider
But ... Mar 31 2020, 11:42 AM
thelogo
[quote name='thelogo' post='2798863' date='Mar 29... Mar 31 2020, 01:45 PM
R1200rider It’s a 2019 Winnebago 4x4 camper van. With suspe... Mar 31 2020, 05:52 PM
bandjoey Talk to your accountant. Trucks over a certain wei... Mar 31 2020, 05:53 PM
thelogo Snake bit i guess . we had a deal at 11k
But guy ... Mar 31 2020, 09:14 PM
KELTY360
But guy... Mar 31 2020, 10:36 PM
thelogo
But gu... Mar 31 2020, 10:48 PM
r_towle Look at motor homes? Mar 31 2020, 09:25 PM
thelogo
I did a bit and its a po... Mar 31 2020, 10:49 PM
thelogo Checking this one out next .
Seems beat up and no... Apr 1 2020, 02:45 PM
thelogo
it is missing at least one digit on the ODO readi... Apr 1 2020, 08:15 PM
914forme
Yes it was in sad shape the odometer had been sw... Apr 1 2020, 08:21 PM
thelogo
Yes it was in sad shape the odometer had been s... Apr 1 2020, 08:41 PM
Superhawk996 Keep in mind who you're buying from.
Previo... Apr 2 2020, 06:21 AM
thelogo
Previ... Apr 2 2020, 06:45 AM
Superhawk996
And i should definitely try to buy within the ne... Apr 2 2020, 08:10 AM
thelogo
And i should definitely try to buy within the n... Apr 2 2020, 09:26 AM
[quote name='Superhawk996' post='2800145' date='A... Apr 2 2020, 11:19 AM
thelogo
[quote name='thelogo' post='2800168' date='Apr 2 ... Apr 3 2020, 07:37 PM
thelogo Is this a scam 12k ?
https://orangecounty.craigsl... Apr 2 2020, 07:58 AM
Superhawk996 Don't forget the whole $20K isn't at ... Apr 2 2020, 10:01 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:16 AM |
