> Its about to go off topic .sprinter van owners chime in, How do you price a used sprinter van
thelogo
post Mar 29 2020, 11:33 AM
Group: Retired Members
This is not for camping or shelter purpose
But im trying to build a mobile dog grooming salon
Ive ruled out new and extremly expensive sprinters
So that leave 1st and 2nd gen
Here is one i made a offer on
https://orangecounty.craigslist.org/cto/d/o...7094720538.html
Are these going to be a maintence nightmare
Or a strong work vehicle
Poease advise (IMG:style_emoticons/default/wub.gif) and feel free to be long winded
914forme
post Apr 1 2020, 06:52 PM
it is missing at least one digit on the ODO reading.
The V6 of that age has a couple of issues. Oil cooler seals leak, oil cooler is in the V of the engine and you have to remove the entire intake, and fuel system ha to be puled to get to it. For two seals, and problem solved.
Fuel injector seals will blow out, and produce a leak, which creates this nice black carbon structure, which is a pain to clean up. Seat needs to be cleaned, and then the copper O needs replaced.
Oil and engine blow by is sucked out of the valve cover into an area right infront of the turbo. That seal leaks, and it fills the turbo, and Intercooler with oil over a long period of time. Seal at the turbo inlet also leaks. And should be replaced, easy to do when you do the filter change.
Maintenance
Oil changes cost me about $180 in parts to do it right 10 quarts of oil.
Trans oil changes where also about $280, every 40K
Fuel filters every 20K
Air filters needed to be checked at oil changes, mine had an affinity to suck all the small insects to large insects off the interstate. And the wold need replace 9 time out of 10. As the pressure built do to restrictive filters the oil draw off the vent system would increase.
Oh it burned 2 Quarts of oil over the 10,000 mile interval, majority of it was from the breather system. I had a Mann Hummel recovery unit on it, I would get about 1.5 quarts out of the system.
Positives, engine ran great, I had a tune done on it, and it would get 27 MPG, never noticed anything I had behind it. I would still be driving it, if I did not find a deal on two BMWs.
thelogo
post Apr 1 2020, 08:15 PM
QUOTE(914forme @ Apr 1 2020, 05:52 PM) *
Maintenance
Yes it was in sad shape the odometer had been switched
At least the guy was honest about that when i asked
Rear main was leaking . cel light was on .
A diaster
But im considering staying far away from these for reasons stated in this post $$$$$$$ bleed
914forme
post Apr 1 2020, 08:21 PM
QUOTE(thelogo @ Apr 1 2020, 10:15 PM) *
A diaster
Most likely not the rear main, Mercedes in the engineering wisdom made the weep drain for the engine V come out in the exact same spot. I would say 99% of the time it is oil cooler seals, still not a fun job, but better than a rear main. (IMG:style_emoticons/default/dry.gif) but not by much.
Actually in a 2WD I would take the rear main over the oil cooler seal.
Keep looking the right one is out there.
thelogo   Its about to go off topic .sprinter van owners chime in   Mar 29 2020, 11:33 AM
JOEPROPER   You may be happier with a Ford Transit... I do so...   Mar 29 2020, 11:47 AM
thelogo   You may be happier with a Ford Transit... I do s...   Mar 29 2020, 11:50 AM
Bmw635   Thought about using trailers? Replacing tow vehicl...   Mar 29 2020, 12:12 PM
thelogo   Thought about using trailers? Replacing tow vehic...   Mar 29 2020, 12:16 PM
Montreal914   what about Ram Promaster van? Front wheel drive, l...   Mar 29 2020, 12:21 PM
thelogo   what about Ram Promaster van? Front wheel drive, ...   Mar 29 2020, 12:31 PM
Craigers17   This one looks like a keeper.   Mar 29 2020, 04:30 PM
thelogo   This one looks like a keeper. That will be the ...   Mar 29 2020, 06:06 PM
Craigers17   This one looks like a keeper. That will be the...   Mar 29 2020, 06:18 PM
thelogo   [quote name='thelogo' post='2798975' date='Mar 29...   Mar 29 2020, 07:07 PM
Larmo63   RE: Its about to go off topic .sprinter van owners chime in   Mar 29 2020, 09:53 PM
thelogo   https://losangeles.craigslist.org/lac/cto/d...7097...   Mar 29 2020, 10:33 PM
UROpartsman   Have also heard that Sprinters are really expensiv...   Mar 30 2020, 12:19 PM
thelogo   Have also heard that Sprinters are really expensi...   Mar 30 2020, 01:19 PM
BigFour1973   Have also heard that Sprinters are really expens...   Mar 30 2020, 01:48 PM
porschetub   Have also heard that Sprinters are really expensi...   Mar 30 2020, 09:16 PM
thelogo   Have also heard that Sprinters are really expens...   Mar 30 2020, 09:41 PM
Superhawk996   The main problem with any of the Sprinters (regard...   Mar 30 2020, 02:00 PM
thelogo   The main problem with any of the Sprinters (regar...   Mar 30 2020, 08:54 PM
PanelBilly   Ford has 84 month 0 interest financing right now w...   Mar 30 2020, 03:14 PM
thelogo   Ford has 84 month 0 interest financing right now ...   Mar 30 2020, 08:46 PM
mepstein   Ford has 84 month 0 interest financing right now...   Mar 30 2020, 09:12 PM
thelogo   [quote name='thelogo' post='2799316' date='Mar 30...   Mar 30 2020, 11:57 PM
Superhawk996   Are you fuckin nuts .... Ive always bought al...   Mar 31 2020, 08:01 AM
JRust   I had a 2004 & a 2005 2500 sprinter vans with ...   Mar 30 2020, 03:29 PM
RickS   Unless you are catering to the rich and famous whe...   Mar 30 2020, 09:14 PM
thelogo   Unless you are catering to the rich and famous wh...   Mar 30 2020, 09:24 PM
SteveL   New high roof cargo van ....$ thats a big n...   Mar 31 2020, 06:54 AM
JOEPROPER   Many smart men and women in business use other peo...   Mar 31 2020, 07:31 AM
andys   Ok folks, read the low/no interest ads, and they g...   Mar 31 2020, 09:01 AM
mepstein   Ok folks, read the low/no interest ads, and they ...   Mar 31 2020, 09:37 AM
JOEPROPER   Ok folks, read the low/no interest ads, and they...   Mar 31 2020, 09:42 AM
thelogo   Ok folks, read the low/no interest ads, and they ...   Mar 31 2020, 09:42 AM
Superhawk996   Ok folks, read the low/no interest ads, and they...   Mar 31 2020, 11:00 AM
R1200rider   This is not for camping or shelter purpose But ...   Mar 31 2020, 11:42 AM
thelogo   [quote name='thelogo' post='2798863' date='Mar 29...   Mar 31 2020, 01:45 PM
R1200rider   It’s a 2019 Winnebago 4x4 camper van. With suspe...   Mar 31 2020, 05:52 PM
bandjoey   Talk to your accountant. Trucks over a certain wei...   Mar 31 2020, 05:53 PM
thelogo   Snake bit i guess . we had a deal at 11k But guy ...   Mar 31 2020, 09:14 PM
KELTY360   Snake bit i guess . we had a deal at 11k But guy...   Mar 31 2020, 10:36 PM
thelogo   Snake bit i guess . we had a deal at 11k But gu...   Mar 31 2020, 10:48 PM
r_towle   Look at motor homes?   Mar 31 2020, 09:25 PM
thelogo   Look at motor homes? I did a bit and its a po...   Mar 31 2020, 10:49 PM
thelogo   Checking this one out next . Seems beat up and no...   Apr 1 2020, 02:45 PM
914forme   it is missing at least one digit on the ODO readin...   Apr 1 2020, 06:52 PM
thelogo   it is missing at least one digit on the ODO readi...   Apr 1 2020, 08:15 PM
914forme   Yes it was in sad shape the odometer had been sw...   Apr 1 2020, 08:21 PM
thelogo   Yes it was in sad shape the odometer had been s...   Apr 1 2020, 08:41 PM
Superhawk996   Keep in mind who you're buying from. Previo...   Apr 2 2020, 06:21 AM
thelogo   Keep in mind who you're buying from. Previ...   Apr 2 2020, 06:45 AM
Superhawk996   And i should definitely try to buy within the ne...   Apr 2 2020, 08:10 AM
thelogo   And i should definitely try to buy within the n...   Apr 2 2020, 09:26 AM
mepstein   [quote name='Superhawk996' post='2800145' date='A...   Apr 2 2020, 11:19 AM
thelogo   [quote name='thelogo' post='2800168' date='Apr 2 ...   Apr 3 2020, 07:37 PM
thelogo   Is this a scam 12k ? https://orangecounty.craigsl...   Apr 2 2020, 07:58 AM
Superhawk996   Don't forget the whole $20K isn't at ...   Apr 2 2020, 10:01 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 08:17 AM
