> Engine bay pad, Adhesive removal
Allan
post Dec 11 2004, 01:42 PM
Teenerless Weenie
Anybody got a recommendation on how to remove all the adhesive they used to hold the engine bay pad in. Wont come off very well with a wire brush and carb cleaner just makes me high.
Howard
post Dec 12 2004, 10:35 AM
Incontin(g)ent Member
QUOTE(trekkor @ Dec 11 2004, 02:50 PM)
When I repaint the engine bay I'm going to use a textured coating, so I'm halfway there already. (IMG:style_emoticons/default/wink.gif)
KT
Just did mine the same way. Nice sharp wood chisels worked fine for major removal. In cool temps with no solvents used, stuff just breaks up and falls off. Then wire brush remnants, vacuum, and wipe with solvent (I used acetone). Not CW quality but OK for me.
Headrage   Engine bay pad   Dec 11 2004, 01:42 PM
Deano   I am up against the same problem. Back in Septembe...   Dec 11 2004, 03:32 PM
9146986   At my shop we use the 2" & 3" green 3M bristle dis...   Dec 11 2004, 03:57 PM
joea9146   Acetone will cut the glue... and also remove some ...   Dec 11 2004, 04:01 PM
trekkor   When I repaint the engine bay I'm going to use...   Dec 11 2004, 04:50 PM
newdeal2   Use spray on or brush on paint remover...I found i...   Dec 11 2004, 05:44 PM
newdeal2   After:   Dec 11 2004, 05:45 PM
newdeal2   After:   Dec 11 2004, 05:46 PM
newdeal2   With engine in [and after cleaning up some of the ...   Dec 11 2004, 05:47 PM
914rrr   3M has a paint stripper wheel that mounts to a sta...   Dec 11 2004, 10:04 PM
vsg914   Standard (500 grade) lacquer thinner will cut the ...   Dec 11 2004, 10:15 PM
rhodyguy   i wish i had known the 3M trick. hours with carb c...   Dec 11 2004, 10:29 PM
kermit   ...   Dec 12 2004, 02:01 AM
newdeal2   The PO made it and it does work. I will be doing a...   Dec 12 2004, 06:45 AM
Bleyseng   lacquer took it right off for me without destroyin...   Dec 12 2004, 10:05 AM
Howard   <...   Dec 12 2004, 10:35 AM
xsboost90   180 grit sandpaper on a d/a....   Dec 12 2004, 10:46 AM
boxstr   Hey Guys and Gals, If you are going to spend all o...   Dec 12 2004, 10:48 AM
Headrage   Thanks guys. I'm going to pull it outside and...   Dec 13 2004, 12:06 PM
Ferg   Great timing on this thread, i'm starting this...   Dec 13 2004, 12:28 PM
mike_the_man   I had a party once and a friend of mine had a litt...   Dec 13 2004, 02:27 PM
- Lo-Fi Version Time is now: 1st July 2025 - 01:41 PM
