FS Misc Parts for 914/912E/911, Excess Project parts, most new 50% off original OBO |
Bulldog9 |
Apr 7 2020, 03:33 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
Using the downtime to clear out some of my leftover parts. All parts unless noted are new and never installed or run. Prices are + shipping. All prices are less than 50% off MSRP, but willing to deal, bundle and move these parts.
UPDATED TO REFLECT SOLD PARTS PM for pictures and details, or more information. 911/912E URO Rear glass weather strip - $25.00 911/912E Porsche Rear Engine Compartment Seal - $25.00 912E Exhaust Gaskets (OEM Porsche #923 11 151 01+C201) - $20.00 911/912E Transmission Mounts (2) - $25.00 *test fit installed, never run. I went with sport mounts instead 911 Front door harness and door wiring dust caps - $10.00 *Used, taken from door of an 86 Carrera 914 Alternator Cooling Plate (2) - $10.00 *Used, good condition 3 POD Plastic 2" VDO Gage Holder - $5.00 2" 12V VDO Clock - $35.00 *test fit installed, ended up using original 911 Heat and volume (control) missing fan switch - $5.00 Used from salvage 911 Headliner Tension Wires 1-4 - $30.00 914 Reman Alternator New never installed - $75.00 SOLD CB Performance Cross Bar Throttle Linkage Pack - Includes Steel Hex Cross Bar - 20 5/8" - $50.00 SOLD 911/912E Front glass weather strip (OEM Made in Germany) - $50.00 SOLD 912E/914 CB Performance Air Filters/Bases with hardware - $25.00 *test fit installed, never run. I went with a pulley system instead. SOLD SCAT bell crank Throttle control linkage - $40.00 *test fit installed, never run. I went with a pulley system instead. SOLD 912E/914 Original Customs Throttle Cable Bracket - $10.00 SOLD 912 E Bursch Exhaust (C 1990) New never installed - $225.00 SOLD 914 Sachs Throwout bearing and bushing caps - $50.00 SOLD NOS Bosch distributor cap and rotor kit (extra cap/condenser) -$10.00 **Fits stock distributor. Truly NOS, is in plastic display package. Will also throw in an extra cap and condenser. I am running the Pertronix plug and play (large distributor) SOLD Set of Lemforder Tie Rod Ends 10710 03 009 - $25.00 **NEW IN BOX. This is for the stock rack and tie rods. I went with the turbo rack which uses different tie rods. SOLD 912E/914 Bosch Fuel Pressure Regulator (Porsche box) - $70.00 SOLD 911/912E Clutch Pedal Return Spring - $5.00 SOLD |
Jack Standz |
Apr 7 2020, 05:47 PM
Member Group: Members Posts: 281 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
Hi, I'm interested in the following two items, but want the alternator if it is a Bosch and the T/o bearing if new. Photos would be nice if you send. Thanks.
PM for pictures and details, or more information. 914 Sachs Throwout bearing and bushing caps 914 Reman Alternator New never installed - $75.00 |
Lo-Fi Version | Time is now: 7th June 2024 - 08:59 AM |
