Outer CV Joint Removal..., Need some advice |
Joseph Mills |
Dec 12 2004, 05:18 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
After removing the four star bolts from the outer CV joint (at the wheel), I removed the axle with the circlip, cage and balls in place (which are all in good shape). However, the CV joint "hub" itself (with the two guide pins) has not budged from the "wheel hub flange".
With the inner CV joint (next to the transaxle), the hub is totally exposed and a few taps with a hammer and then careful prying with a screwdriver and the hub comes right off the "transaxle flange". But since the outer hub is located deep inside the suspension arm, it is difficult to get to. Any advice, tips, or tools that may help me break this thing loose? |
Aaron Cox |
Dec 12 2004, 05:59 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
pull the stub axle then. one BIG bolt on the wheel side with a BFH or cheater bar or an impact wrench.
Lo-Fi Version | Time is now: 1st June 2024 - 07:55 PM |
