SteveH,Dec 12 2004, 06:08 PM]
"I'm guessing that you are saying that the body of the cv joint is attached to the stub axle, while you were able to remove the axle shaft along with the cage and balls still attached."
Steve, you are so totally correct on everything. That is exactly what I did.
"I'm actually surprised you were able or incline to remove it, as having the axle in place gives you something to apply force to in removing the cv from the stub axle."
It just kinda came out as I was trying to do what you describe below. The cage got slightly turned enough that a bearing came out and in trying to straighten the axle back up the whole thing came out.
"I usually just push the axle fully into the cv, then quickly snap it to the fully extended position to break it loose."
That is no longer an option now.
"In your case I'd guess you have two options.
1. Remove the stub axle, which will require replacing the wheel bearing, as it is damaged from removing the stub."
Not quite ready to do that yet.
or
"2. get a thin pry bar, and work your way slowly around the cv, applying lateral force to shimmy it out, a little at a time. Actually, if you were careful, I bet the right bearing puller/slide hammer could fit into the center of the cv, grab it from the inside edges, so not to damage any mating surfaces, and with a few pops it would come unseated. You may be able to borrow one from a local parts store if you don't already have one."
I've tried a carpenters crow bar, a drum brake adjusting tool, etc. No luck so far. But I think you're correct about the "right" puller/slide hammer.
Do you think a bit of heat might help?
