Backfire in the throttle body |
gjames |
Apr 13 2020, 08:29 AM
Newbie Group: Members Posts: 10 Joined: 3-March 13 From: Virginia Member No.: 15,606 Region Association: None |
My 914 had not run for 3 years. I soaked the cylinders in WD40 for a couple days before starting. I discovered heavy rust in the fuel tank so I replaced:
Tank, hoses and pump. Injectors and engine bay fuel lines And Flushed the long fuel lines until they ran clean The engine started but there was no power, poor idle I Replaced: Points/plugs/condenser/coil. Reset timing and idle (The dwell is no high side- 58) Power is back and idle is good. The Problem: When I give it gas, it will back fire into the throttle body. It seems to happen a 2k - 3k rpm range. It's doesn't happen every time. Ideas? |
gjames |
Apr 14 2020, 08:39 AM
Thanks for the responses!!!
Last night I reset the points gap and got the dwell within specs, and then I reset the timing. The problem is now fixed. |
Lo-Fi Version | Time is now: 1st June 2024 - 06:52 PM |
