Rear soft brake lines, Is it possible to change them with the engine in the car? |
bigkensteele |
Apr 19 2020, 06:06 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
As the subject inquires, can this be done?
rgalla9146 |
Apr 19 2020, 06:45 PM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
It's easy.
Snip the old hose off right at the fitting attached to the chassis. Place your 11mm crows foot wrench on the fitting above the bracket and block it to keep it from rotating. Use a deep 14mm socket on a long extension to rotate the hose fitting off the hard line nut. Use a flat screwdriver to lever the clip off the fitting. Lay the flat of the screwdriver at the open end of the clip and lever it off against the chassis |
Lo-Fi Version | Time is now: 11th June 2024 - 03:40 AM |
