Led Bulbs for Fog Lights |
PCH |
Apr 1 2020, 01:06 PM
Member Group: Members Posts: 141 Joined: 3-January 19 From: Santa Barbara Member No.: 22,772 Region Association: Southern California |
I know this topic has come up before without a specific LED bulb being mentioned. Are there any plug and play LED bulbs for fog lights? I have searched the internet and not found any. Just making sure I didn't miss anything.
Thank you, Peter |
eric9144 |
Apr 19 2020, 09:39 PM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
@Spoke those are interesting--those look like the guts to the "5 bolt" (euro) driving lights vs the US Fogs--that rear bulb housing takes an H3 straight from the back vs the Fog that takes an incandescent up from the bottom. The lenses on those weren't fluted like the US fogs but were seemingly glued like a sealed beam. There's an oven method to separate them though I've never personally tried.
Spoke |
Apr 19 2020, 10:00 PM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
@Spoke those are interesting--those look like the guts to the "5 bolt" (euro) driving lights vs the US Fogs--that rear bulb housing takes an H3 straight from the back vs the Fog that takes an incandescent up from the bottom. The lenses on those weren't fluted like the US fogs but were seemingly glued like a sealed beam. There's an oven method to separate them though I've never personally tried. @eric9144 Thanks. The lens does appear to be bonded to the reflector. The white glue/epoxy seems professionally applied as it is very neatly done. The glue is hard as a rock. I can't chip it or slice it off. The lens is larger than the standard 914 foglight lens and the bezel inside diameter is larger as well. The outer diameter is identical and the lens/bezel/reflector fits in the rear fixture. Notice how much thinner the H3 bezel on the right is compared to a standard 914 foglight bezel. The glass lens shown is a later 914 lens and just falls right into the H3 bezel. Even the clips shown in an earlier post are different from the standard 914 clips (and 914rubber clips). Attached image(s) |
Lo-Fi Version | Time is now: 8th June 2024 - 01:04 AM |
