Car pulls to the right, Any suggestions as cause? |
gturner008 |
Apr 22 2020, 12:04 PM
Member Group: Members Posts: 127 Joined: 21-April 20 From: Toronto Member No.: 24,163 Region Association: Canada |
One issue on my car just purchased, a 1976, is that the car constantly pulls to the right. I've checked the obvious, like tire pressures etc. When I went through the paper work file - I noticed two occasions when the previous owner mentioned this to the service department.
So perhaps its been an issue for some time. Any ideas on cause? I'm assuming simple tracking won't fix it. Would a full four wheel geometry fix the issue? I've checked that no wheel brakes are binding. I'm a bit stumped. Any advice appreciated. |
ahycaramba |
Apr 22 2020, 01:31 PM
“I live my life a quarter mile at a time.” Group: Members Posts: 161 Joined: 17-March 15 From: Murrieta, California Member No.: 18,534 Region Association: Southern California |
It could be a variety of things. Since the car is new to you. I highly recommend to have your car aligned by someone familiar with 914's. just to get a base starting point for whats going on with your suspension. With an alignment you can see if its a simple toe adjustment all the way to bent parts.
If the alignment is good and brakes are not dragging it and you still have a pull, It could be caused by a bad tire pulling to one side. To check on tire pull a simple tire rotation from side to side (even rotating rear tires) should either correct the problem or cause a pull to the other side. Hope this helps |
Lo-Fi Version | Time is now: 10th June 2024 - 09:26 AM |
