| ctc911ctc |
Apr 24 2020, 07:02 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,323 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
All Teeners,
Focusing on the things that bug me. When driving down a bumpy road (which is every road in the Boston area) the top makes a great deal of noise on top of the sail. I have all new 914Rubber front and back and all over the car BTW. I have tightened the latches as tight as I dare. Both doors are tight and fit well. I also have added Brad Meyers tub stiffness: https://914ltd.com/product/porsche-914-chas...-repair-panels/ Perhaps a few thoughts as to how to test for body flex longitudinal? Might this be the culprit, twisting??? Thank you, CTC911CTC |
| Superhawk996 |
Apr 24 2020, 07:58 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Too high of expectation
These are not modern cars. As previously stated by Mark, Silicone Spray and Armor All can help. Krytox is what the auto industry uses on certain problem areas like windshield surrond trim and what will be most effective of the targa rubber to body interfaces. There are all kinds of grades of Krytox ranging from https://www.ebay.com/i/184197562621?chn=ps&...BiABEgIXVfD_BwE to more OEM versions that cost up to $100 for 2 oz but it lasts and it works and 2oz will do hundreds of cars. If you really want to eliminate all squeeks and rattles, you're going to have to buy either NVH felt flocking like this https://www.amazon.com/Anti-Squeak-Rattle-A...d/dp/B012D23HDE or anti-squeek polyethylene tape https://www.grainger.com/product/15D284?gcl...33;437026409190! Use at interfaces between trim parts that can move relative to each other. If you've ever worked on a modern Japanese or German vehicle you'll have an idea of where this stuff goes. |
| ctc911ctc |
Apr 24 2020, 08:41 AM
Superhawk (Studebaker guy?) thank you!
Seems that both you AND I have too high expectations. How else would you know about all of these great remedies? I will try them this weekend, Thank you! Too high of expectation These are not modern cars. As previously stated by Mark, Silicone Spray and Armor All can help. Krytox is what the auto industry uses on certain problem areas like windshield surrond trim and what will be most effective of the targa rubber to body interfaces. There are all kinds of grades of Krytox ranging from https://www.ebay.com/i/184197562621?chn=ps&...BiABEgIXVfD_BwE to more OEM versions that cost up to $100 for 2 oz but it lasts and it works and 2oz will do hundreds of cars. If you really want to eliminate all squeeks and rattles, you're going to have to buy either NVH felt flocking like this https://www.amazon.com/Anti-Squeak-Rattle-A...d/dp/B012D23HDE or anti-squeek polyethylene tape https://www.grainger.com/product/15D284?gcl...33;437026409190! Use at interfaces between trim parts that can move relative to each other. If you've ever worked on a modern Japanese or German vehicle you'll have an idea of where this stuff goes. |
ctc911ctc How much Noise should the TOP make? Apr 24 2020, 07:02 AM
Mark Henry That's just the gerbils in the engine complain... Apr 24 2020, 07:33 AM
Superhawk996
Seems... Apr 24 2020, 09:58 AM
VegasRacer I went with the low tech, non concours soultion.
J... Apr 24 2020, 08:48 AM
rhodyguy Try the one sided felt tape in the recesses on the... Apr 24 2020, 08:49 AM
jim_hoyland ? Possible 914 Rubber upgrade ? :) Apr 24 2020, 09:13 AM
porschetub
Jim 914rubbe... Apr 24 2020, 04:32 PM
Chris914n6 Likely the rear latch bumpers are dry & hard. ... Apr 24 2020, 05:11 PM
jim_hoyland Could those latch bumpers be replaced ? Apr 24 2020, 05:16 PM
Chris914n6
uro make... Apr 24 2020, 07:39 PM
bandjoey I put a piece of very small rubber hose on the lat... Apr 24 2020, 05:49 PM
Mikey914 Your noise is more than likely the rubber bumpers ... Apr 24 2020, 05:54 PM
brcacti Mine has many rattles and noises, wind sounds from... Apr 24 2020, 06:10 PM
PanelBilly Mine also squeaks too much. If I put a scrap of po... Apr 24 2020, 08:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:09 AM |
