| mb911 |
Apr 14 2020, 08:37 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,729 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
I looking for fuel tank carbon canister that would be easy to hide.. Any thoughts or suggestions?
| JeffBowlsby |
Apr 24 2020, 08:58 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,222 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
If your canister has 2 small ports, check them carefully. Seems to me I have seen them like that but one is not a port its solid.
Function of the canister relies on intake airflow from the engine fan through the filter media, to the exit port back to the intake. Fuel vapors are just along fro the ride. Factory says replace the charcoal every 50K miles. Attached image(s)
| ClayPerrine |
Apr 24 2020, 10:12 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
If your canister has 2 small ports, check them carefully. Seems to me I have seen them like that but one is not a port its solid. Function of the canister relies on intake airflow from the engine fan through the filter media, to the exit port back to the intake. Fuel vapors are just along fro the ride. Factory says replace the charcoal every 50K miles. Betty's car is about 350,000 miles overdue.... Where can the charcoal be purchased? |
| Superhawk996 |
Apr 24 2020, 10:31 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
mb911 Charcoal canister Apr 14 2020, 08:37 PM
Steve I have mine mounted in front of the battery where ... Apr 14 2020, 10:40 PM
mb911
I have mine mounted in front of the battery where... Apr 15 2020, 05:35 AM
Steve
[quote name='Steve' post='2804475' date='Apr 14 2... Apr 15 2020, 06:48 AM
Steve
[quote name='Steve' post='2804475' date='Apr 14 ... Apr 15 2020, 07:06 PM
Steve With the canister in the engine compartment, you o... Apr 15 2020, 07:13 PM
Steve In the originality forum, you can see the stock lo... Apr 15 2020, 07:17 PM
mb911 Thanks.. I have some thinking to do on this Apr 16 2020, 04:54 AM
jaredmcginness Not to Hi jack.... but while on the topic.
If run... Apr 16 2020, 06:26 AM
Steve
If ru... Apr 16 2020, 06:31 AM
Mark Henry
To be clear I have Carbs with a GT filler neck. ... Apr 16 2020, 12:34 PM
mb911 To be clear I have Carbs with a GT filler neck. Ju... Apr 16 2020, 06:38 AM
Steve
To be clear I have Carbs with a GT filler neck. J... Apr 16 2020, 10:33 AM
porschetub
To be clear I have Carbs with a GT filler neck. J... Apr 16 2020, 03:31 PM
Steve
To be clear I have Carbs with a GT filler neck. ... Apr 16 2020, 05:19 PM
914Toy I have a 911 engine with carbs. The filter return ... Apr 16 2020, 08:51 AM
Mark Henry It's funny I've been too lazy to finish mo... Apr 16 2020, 05:50 PM
gonzo54 I bought a plastic charcoal canister that I can re... Apr 23 2020, 05:39 PM
gonzo54
This is the plastic canister I bought and hopef... Apr 23 2020, 05:43 PM
Steve
This is the plastic canister I bought and hope... Apr 23 2020, 06:18 PM
JeffBowlsby :) Apr 23 2020, 06:57 PM
gonzo54 Jeff, Thanks for the diagram. I questioned the di... Apr 24 2020, 07:20 AM
If your canister has 2 small ports, check them c... Apr 24 2020, 10:58 AM
ClayPerrine
I've also read that just not using the car f... Apr 24 2020, 12:44 PM
Rob-O
If your canister has 2 small ports, check them c... Apr 24 2020, 12:53 PM
BeatNavy
[quote name='ClayPerrine' post='2807843' date='Ap... Apr 24 2020, 01:37 PM
[quote name='Rob-O' post='2807891' date='Apr... Apr 24 2020, 05:23 PM
Steve
[quote name='ClayPerrine' post='2807843' date='Ap... Apr 24 2020, 04:28 PM
gonzo54 Thanks for the source for new charcoal. Hopefully... Apr 24 2020, 05:24 PM
Steve There is a nice video from Ian
https://m.youtube.c... Apr 24 2020, 07:15 PM
bbrock I keep thinking I'll get time to post this as ... Apr 25 2020, 10:41 AM
Mikey914
I keep thinking I'll get time to post this as... Apr 25 2020, 05:40 PM
Rob-O Could the larger, aquarium pellets be broken into ... Apr 25 2020, 11:05 AM
bbrock
Could the larger, aquarium pellets be broken into... Apr 25 2020, 11:25 AM
914Toy Granulated carbon is used in the gold mining indus... Apr 25 2020, 01:24 PM
Mikey914
Granulated carbon is used in the gold mining indu... Apr 25 2020, 05:49 PM
FlacaProductions Like @[url=http://www.914world.com/bbs2/index.php... Apr 25 2020, 06:36 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:01 PM |
