| ctc911ctc |
Apr 24 2020, 07:02 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,323 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
All Teeners,
Focusing on the things that bug me. When driving down a bumpy road (which is every road in the Boston area) the top makes a great deal of noise on top of the sail. I have all new 914Rubber front and back and all over the car BTW. I have tightened the latches as tight as I dare. Both doors are tight and fit well. I also have added Brad Meyers tub stiffness: https://914ltd.com/product/porsche-914-chas...-repair-panels/ Perhaps a few thoughts as to how to test for body flex longitudinal? Might this be the culprit, twisting??? Thank you, CTC911CTC |
| Chris914n6 |
Apr 24 2020, 05:11 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,528 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Likely the rear latch bumpers are dry & hard. Easy test is to undo the rear latches and listen.
ctc911ctc How much Noise should the TOP make? Apr 24 2020, 07:02 AM
Mark Henry That's just the gerbils in the engine complain... Apr 24 2020, 07:33 AM
Superhawk996 Too high of expectation
These are not modern cars... Apr 24 2020, 07:58 AM
ctc911ctc Superhawk (Studebaker guy?) thank you!
Seems ... Apr 24 2020, 08:41 AM
Superhawk996
Seems... Apr 24 2020, 09:58 AM
VegasRacer I went with the low tech, non concours soultion.
J... Apr 24 2020, 08:48 AM
rhodyguy Try the one sided felt tape in the recesses on the... Apr 24 2020, 08:49 AM
jim_hoyland ? Possible 914 Rubber upgrade ? :) Apr 24 2020, 09:13 AM
porschetub
Jim 914rubbe... Apr 24 2020, 04:32 PM
jim_hoyland Could those latch bumpers be replaced ? Apr 24 2020, 05:16 PM
Chris914n6
uro make... Apr 24 2020, 07:39 PM
bandjoey I put a piece of very small rubber hose on the lat... Apr 24 2020, 05:49 PM
Mikey914 Your noise is more than likely the rubber bumpers ... Apr 24 2020, 05:54 PM
brcacti Mine has many rattles and noises, wind sounds from... Apr 24 2020, 06:10 PM
PanelBilly Mine also squeaks too much. If I put a scrap of po... Apr 24 2020, 08:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:07 AM |
