> Charcoal canister
mb911
post Apr 14 2020, 08:37 PM
I looking for fuel tank carbon canister that would be easy to hide.. Any thoughts or suggestions?
Rob-O
post Apr 25 2020, 11:05 AM
Could the larger, aquarium pellets be broken into smaller pieces to more closely match the original size?
I’d think just the replenishment would make the biggest difference. If the 4mm pellets lasted 50,000 miles maybe just reduce the mileage before changing them out with the larger pellets.
The CW slope is definitely slippery. I can’t imagine a judge opening a plastic charcoal container to check/measure the size of the pellets.
bbrock
post Apr 25 2020, 11:25 AM
QUOTE(Rob-O @ Apr 25 2020, 11:05 AM) *
Maybe a chemist can chime in on this but someone on another forum said something about both size and iodine content made a difference whether the charcoal is optimized to filter liquid or gas. I don't know how much is true. I can see where the larger pellets would allow a higher percentage of the gas vapor to travel through the canister with less time in contact with the charcoal, but if everything is hooked up right, anything not adsorbed to the charcoal would wind up in the fuel intake and be burned in the engine.
I agree with you. There might be a bit of a difference but is it worth getting our unders in a twist over? However, if a vendor could buy the "good stuff" in bulk and retail it competitively with aquarium charcoal, then why not get the good stuff? AFAIC, I'm set for quite a few miles unless I start smelling gas.
(IMG:style_emoticons/default/av-943.gif) I like to see that! They might, of course, notice the difference between an early metal canister and late plastic one though. I wanted to stick with original in mine. Plus, I'm a CSOB who didn't want to spend money on another canister. (IMG:style_emoticons/default/biggrin.gif)
mb911   Charcoal canister   Apr 14 2020, 08:37 PM
Steve   I have mine mounted in front of the battery where ...   Apr 14 2020, 10:40 PM
mb911   I have mine mounted in front of the battery where...   Apr 15 2020, 05:35 AM
Steve   [quote name='Steve' post='2804475' date='Apr 14 2...   Apr 15 2020, 06:48 AM
Steve   [quote name='Steve' post='2804475' date='Apr 14 ...   Apr 15 2020, 07:06 PM
Steve   With the canister in the engine compartment, you o...   Apr 15 2020, 07:13 PM
Steve   In the originality forum, you can see the stock lo...   Apr 15 2020, 07:17 PM
mb911   Thanks.. I have some thinking to do on this   Apr 16 2020, 04:54 AM
jaredmcginness   Not to Hi jack.... but while on the topic. If run...   Apr 16 2020, 06:26 AM
Steve   Not to Hi jack.... but while on the topic. If ru...   Apr 16 2020, 06:31 AM
Mark Henry   To be clear I have Carbs with a GT filler neck. ...   Apr 16 2020, 12:34 PM
mb911   To be clear I have Carbs with a GT filler neck. Ju...   Apr 16 2020, 06:38 AM
Steve   To be clear I have Carbs with a GT filler neck. J...   Apr 16 2020, 10:33 AM
porschetub   To be clear I have Carbs with a GT filler neck. J...   Apr 16 2020, 03:31 PM
Steve   To be clear I have Carbs with a GT filler neck. ...   Apr 16 2020, 05:19 PM
914Toy   I have a 911 engine with carbs. The filter return ...   Apr 16 2020, 08:51 AM
Mark Henry   It's funny I've been too lazy to finish mo...   Apr 16 2020, 05:50 PM
gonzo54   I bought a plastic charcoal canister that I can re...   Apr 23 2020, 05:39 PM
gonzo54   This is the plastic canister I bought and hopef...   Apr 23 2020, 05:43 PM
Steve   This is the plastic canister I bought and hope...   Apr 23 2020, 06:18 PM
JeffBowlsby   :)   Apr 23 2020, 06:57 PM
gonzo54   Jeff, Thanks for the diagram. I questioned the di...   Apr 24 2020, 07:20 AM
JeffBowlsby   If your canister has 2 small ports, check them car...   Apr 24 2020, 08:58 AM
ClayPerrine   If your canister has 2 small ports, check them ca...   Apr 24 2020, 10:12 AM
Superhawk996   Betty's car is about 350,000 miles overdue...   Apr 24 2020, 10:31 AM
mepstein   If your canister has 2 small ports, check them c...   Apr 24 2020, 10:58 AM
ClayPerrine   I've also read that just not using the car f...   Apr 24 2020, 12:44 PM
Rob-O   If your canister has 2 small ports, check them c...   Apr 24 2020, 12:53 PM
BeatNavy   [quote name='ClayPerrine' post='2807843' date='Ap...   Apr 24 2020, 01:37 PM
mepstein   [quote name='Rob-O' post='2807891' date='Apr...   Apr 24 2020, 05:23 PM
Steve   [quote name='ClayPerrine' post='2807843' date='Ap...   Apr 24 2020, 04:28 PM
gonzo54   Thanks for the source for new charcoal. Hopefully...   Apr 24 2020, 05:24 PM
Steve   There is a nice video from Ian https://m.youtube.c...   Apr 24 2020, 07:15 PM
bbrock   I keep thinking I'll get time to post this as ...   Apr 25 2020, 10:41 AM
Mikey914   I keep thinking I'll get time to post this as...   Apr 25 2020, 05:40 PM
Rob-O   Could the larger, aquarium pellets be broken into ...   Apr 25 2020, 11:05 AM
bbrock   Could the larger, aquarium pellets be broken into...   Apr 25 2020, 11:25 AM
914Toy   Granulated carbon is used in the gold mining indus...   Apr 25 2020, 01:24 PM
Mikey914   Granulated carbon is used in the gold mining indu...   Apr 25 2020, 05:49 PM
FlacaProductions   Like @[url=http://www.914world.com/bbs2/index.php...   Apr 25 2020, 06:36 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:01 PM
