> Hubs for my 3" 911 struts
Literati914
post Apr 16 2020, 12:17 PM
I have a set of early 3" 911T front struts that I need to get hubs for.. is there any chance that a set from a 911S (991 version) would work ? I found a smoking deal on 'em..
narrow body car if that matters, cookie cutter or deep six replicas being considered. TIA.
Literati914
post Apr 26 2020, 12:04 AM
QUOTE(mepstein @ Apr 24 2020, 08:14 AM) *
QUOTE(Literati914 @ Apr 24 2020, 12:54 AM) *
. are 914/6 (specific) front rotors vented ?
Solid rotors front and back.
QUOTE(davep @ Apr 25 2020, 10:25 PM) *
All the info I have says the 914/6 had vented front rotors with 40mm hubs. ..
Ok, well.. what about the 911's with M-calipers.. what were their front setups, anyone? (since the Brembo is supposed to have the same offset as well as having 3" mounts.
davep
post Apr 26 2020, 10:57 AM
914 Historian
QUOTE(Literati914 @ Apr 25 2020, 10:04 PM) *
Some 911T came with solid rotors, but I think most 911 came with vented rotors. The M calipers would have spacers between the halves to accommodate the vented rotors. I'm not certain about the hubs, but somehow I think that solid rotor had a different (thinner) hub.
Literati914   Hubs for my 3" 911 struts   Apr 16 2020, 12:17 PM
Literati914   .. just realized the 991 is the 7th generation, so...   Apr 16 2020, 12:21 PM
mepstein   I probably have early hubs if you are in the marke...   Apr 16 2020, 12:40 PM
Mark Henry   From '68 to '83 if I read this right. htt...   Apr 16 2020, 12:47 PM
Literati914   ..to add to my confusion I want vented rotors and ...   Apr 16 2020, 01:19 PM
mepstein   ..to add to my confusion I want vented rotors and...   Apr 16 2020, 01:52 PM
mepstein   ..to add to my confusion I want vented rotors and...   Apr 16 2020, 01:53 PM
Literati914   But didn't the original 914/6 use 32mm hubs an...   Apr 16 2020, 05:07 PM
Mark Henry   I have 911T struts which BTW are the actual 914/6 ...   Apr 16 2020, 05:35 PM
Mark Henry   wrong post   Apr 17 2020, 09:00 AM
bigkensteele   You want 40mm, but there are early and late on tho...   Apr 16 2020, 09:09 PM
Literati914   I have 911T struts which BTW are the actual 914/6...   Apr 23 2020, 12:26 AM
Mark Henry   If it's on the outside of the hub I can look f...   Apr 23 2020, 09:16 AM
Literati914   I have 911T struts .., 40mm hubs, 914/6 rotors an...   Apr 23 2020, 10:54 PM
mepstein   [quote name='Mark Henry' post='2805086' date='Apr...   Apr 24 2020, 07:14 AM
Mark Henry   [quote name='Literati914' post='2807726' date='Ap...   Apr 24 2020, 09:07 AM
Literati914   [quote name='Literati914' post='2807726' date='Ap...   Apr 25 2020, 01:23 PM
davep   All the info I have says the 914/6 had vented fron...   Apr 25 2020, 09:25 PM
Literati914   [quote name='Literati914' post='2807726' date='Ap...   Apr 26 2020, 12:04 AM
davep   Ok, well.. what about the 911's with M-caliper...   Apr 26 2020, 10:57 AM
mepstein   Ok, well.. what about the 911's with M-calipe...   Apr 26 2020, 11:00 AM
Mark Henry   Well I'm wrong again, the hubs on my cookies t...   Apr 26 2020, 05:19 AM
Literati914   ..I'm going to have to measure the front hubs...   Apr 26 2020, 09:07 PM
mepstein   ..I'm going to have to measure the front hub...   Apr 26 2020, 09:26 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:12 PM
