| Literati914 |
Apr 16 2020, 12:17 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,237 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I have a set of early 3" 911T front struts that I need to get hubs for.. is there any chance that a set from a 911S (991 version) would work ? I found a smoking deal on 'em..
narrow body car if that matters, cookie cutter or deep six replicas being considered. TIA. |
| Literati914 |
Apr 26 2020, 12:04 AM
. are 914/6 (specific) front rotors vented ? Solid rotors front and back. All the info I have says the 914/6 had vented front rotors with 40mm hubs. .. Ok, well.. what about the 911's with M-calipers.. what were their front setups, anyone? (since the Brembo is supposed to have the same offset as well as having 3" mounts. |
| davep |
Apr 26 2020, 10:57 AM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,359 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Ok, well.. what about the 911's with M-calipers.. what were their front setups, anyone? (since the Brembo is supposed to have the same offset as well as having 3" mounts. Some 911T came with solid rotors, but I think most 911 came with vented rotors. The M calipers would have spacers between the halves to accommodate the vented rotors. I'm not certain about the hubs, but somehow I think that solid rotor had a different (thinner) hub. |
| mepstein |
Apr 26 2020, 11:00 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Ok, well.. what about the 911's with M-calipers.. what were their front setups, anyone? (since the Brembo is supposed to have the same offset as well as having 3" mounts. Some 911T came with solid rotors, but I think most 911 came with vented rotors. The M calipers would have spacers between the halves to accommodate the vented rotors. I'm not certain about the hubs, but somehow I think that solid rotor had a different (thinner) hub. I probably messed up with thinking the fronts on the 914-6 were solid. I did put unvented M calipers and rotors on the front of my conversion car and everything worked fine with early (non hub centric) hubs. |
Literati914 Hubs for my 3" 911 struts Apr 16 2020, 12:17 PM
Literati914 .. just realized the 991 is the 7th generation, so... Apr 16 2020, 12:21 PM
mepstein I probably have early hubs if you are in the marke... Apr 16 2020, 12:40 PM
Mark Henry From '68 to '83 if I read this right.
htt... Apr 16 2020, 12:47 PM
Literati914 ..to add to my confusion I want vented rotors and ... Apr 16 2020, 01:19 PM
..to add to my confusion I want vented rotors and... Apr 16 2020, 01:52 PM
..to add to my confusion I want vented rotors and... Apr 16 2020, 01:53 PM
Literati914 But didn't the original 914/6 use 32mm hubs an... Apr 16 2020, 05:07 PM
Mark Henry I have 911T struts which BTW are the actual 914/6 ... Apr 16 2020, 05:35 PM
Mark Henry wrong post Apr 17 2020, 09:00 AM
bigkensteele You want 40mm, but there are early and late on tho... Apr 16 2020, 09:09 PM
Literati914
I have 911T struts which BTW are the actual 914/6... Apr 23 2020, 12:26 AM
Mark Henry If it's on the outside of the hub I can look f... Apr 23 2020, 09:16 AM
Literati914
I have 911T struts .., 40mm hubs, 914/6 rotors an... Apr 23 2020, 10:54 PM
[quote name='Mark Henry' post='2805086' date='Apr... Apr 24 2020, 07:14 AM
Mark Henry
[quote name='Literati914' post='2807726' date='Ap... Apr 24 2020, 09:07 AM
Literati914
[quote name='Literati914' post='2807726' date='Ap... Apr 25 2020, 01:23 PM
davep All the info I have says the 914/6 had vented fron... Apr 25 2020, 09:25 PM
Mark Henry Well I'm wrong again, the hubs on my cookies t... Apr 26 2020, 05:19 AM
Literati914
..I'm going to have to measure the front hubs... Apr 26 2020, 09:07 PM
..I'm going to have to measure the front hub... Apr 26 2020, 09:26 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:21 PM |
