> High Mounted 3rd Brake Strobe Light, A few pics, video and contacts, $7.94 total!
oakdalecurtis
post Apr 26 2017, 11:03 AM
Oakdalecurtis
Finally attached an LED high mount 3rd brake light. Added a strobe module to make it really pop.
Here's a short video of it in action. If you watch it in slow mo, you can see the LED lights come on significantly before the car's incandescent brake light bulbs.
https://www.youtube.com/watch?v=TaQ6msHbFbA
I drilled holes in the LED side mounts so I could use small screws to attach it to the underside of the targa bar instead of just the sticky tape on it. The small holes in the curved mounts' exterior allow screwdriver access to the screws inside the mount. I had to remove the engine lid to allow my drill to fit under the targa bar to drill the small pilot holes for the mounting screws. I ran the thin LED dual wire lead up through another small hole drilled through the LED mount and into the targa bar. Then the wire goes out through a small hole drilled under the rear targa bar chrome trim. After adding a dual wire extension, I ran the wire along under the rear targa trim to the edge trim, then down under that piece. I got the wire into the engine bay through a small downward hole under the side trim and through another small hole in the engine bay side near the trunk hinge attachment point. From there it was easy to follow the existing wire harness back to the brake light connection point. I put the strobe module in-line right there. Do not ground the negative from the LED light before reaching the strobe module since the module needs both positive and negative wires in and out. Ground the negative lead coming out of the strobe module. Finally, using a piggy back connector finishes the connection to the brake light lead without cutting any harness's. Btw, here's a link to the LED light at Amazon for $1.85 and free shipping! Don't know how the can do that!
http://www.ebay.com/itm/Red-14-LED-Car-Aut...Nv4&vxp=mtr
And here's a link to the strobe module for $6.09 and free shipping.
https://www.amazon.com/CARCHET-Strobe-Contr...e/dp/B00I4J35HY
A little wire and $7.94 and you're in business!
mrholland2
post Apr 29 2020, 01:24 PM
These need to be retina damagingly bright. Lasers? Phasers? Romulan disruptors?
oakdalecurtis   High Mounted 3rd Brake Strobe Light   Apr 26 2017, 11:03 AM
eriqx   nice work! very clean. and super-necessary...   Apr 26 2017, 11:35 AM
Mark Henry   No good for me....it blocks the rear view mirror v...   Apr 26 2017, 11:49 AM
oakdalecurtis   No good for me....it blocks the rear view mirror ...   Apr 26 2017, 02:17 PM
Mblizzard   No good for me....it blocks the rear view mirror ...   May 3 2020, 02:48 PM
BillC   What about flipping it over and mounting it to the...   Apr 26 2017, 04:13 PM
oakdalecurtis   What about flipping it over and mounting it to th...   Apr 26 2017, 08:51 PM
RickS   Rather than reinvent the wheel, buy one of these. ...   Apr 26 2017, 10:19 PM
87m491   Given the small size, I was thinking double sided ...   Apr 27 2017, 04:31 AM
StarBear   Rather than reinvent the wheel, buy one of these....   Apr 29 2020, 03:04 PM
RickS   Pic of the light.   Apr 26 2017, 10:39 PM
mepstein   Im going to try some of the little, high strength ...   Apr 27 2017, 05:54 AM
anderssj   Im going to try some of the little, high strength...   Apr 27 2017, 11:10 AM
mepstein   Im going to try some of the little, high strengt...   Apr 27 2017, 03:08 PM
Gatornapper   Steve - so how did Terri reach the brake pedal fr...   Apr 30 2020, 06:59 AM
Keith914   Here is my application with a 2 foot strip inside ...   Apr 27 2017, 09:00 AM
Keith914   Here is my application with a 2 foot strip inside...   Apr 27 2017, 09:32 AM
Spoke   Finally attached an LED high mount 3rd brake ligh...   Apr 27 2017, 10:06 AM
oakdalecurtis   A couple of things to consider if you plan on addi...   Apr 27 2017, 10:28 AM
Spoke   A couple of things to consider if you plan on add...   Apr 27 2017, 10:40 AM
Keith914   A couple of things to consider if you plan on add...   Apr 27 2017, 02:34 PM
dangrouche   Hey oakldalecurtis, a trademark infringement!...   Apr 27 2017, 10:41 AM
oakdalecurtis   Hey oakldalecurtis, a trademark infringement...   Apr 27 2017, 10:58 AM
stugray   Nice work! I have always wanted to build one ...   Apr 27 2017, 03:24 PM
anderssj   Nice work! I have always wanted to build one...   Apr 27 2017, 09:00 PM
Spoke   This one is 38949B at Summit Racing and is 12 inch...   Apr 27 2017, 08:16 PM
Gatornapper   Jerry - Thanks! Like that one the best! ...   May 4 2020, 07:10 PM
mrholland2   These need to be retina damagingly bright. Lasers?...   Apr 29 2020, 01:24 PM
ClayPerrine   These need to be retina damagingly bright. Lasers...   Apr 29 2020, 01:35 PM
GregAmy   I find strobing/flashing brake lights to be extrem...   Apr 29 2020, 01:41 PM
oakdalecurtis   I find strobing/flashing brake lights to be extre...   Apr 29 2020, 02:21 PM
RickS   I find strobing/flashing brake lights to be extre...   May 4 2020, 08:14 PM
Mblizzard   I find strobing/flashing brake lights to be extr...   May 5 2020, 07:32 AM
Mark Henry   [quote name='RickS' post='2811731' date='May 4 20...   May 5 2020, 08:45 AM
Cairo94507   I think if you came to CA and drove around you may...   Apr 29 2020, 02:51 PM
bandjoey   Lots of 3rd brake light threads. Here's mine...   Apr 29 2020, 06:19 PM
bandjoey   Someone asked about how the wires went through the...   May 2 2020, 10:20 PM
North Coast Jim   Here's mine. I live is a Sumer tourist area an...   May 3 2020, 10:15 AM
anderssj   Here's mine. I live is a Sumer tourist area a...   May 3 2020, 11:50 AM
FlacaProductions   one option for a flasher: https://www.superbrightl...   May 3 2020, 12:18 PM
Literati914   This one is 38949B at Summit Racing and is 12 inc...   May 3 2020, 01:13 PM
Spoke   This one is 38949B at Summit Racing and is 12 in...   May 4 2020, 07:35 AM
Mark Henry   [quote name='Literati914' post='2811299' date='Ma...   May 4 2020, 12:22 PM
FlacaProductions   @Literati914 - i *believe* if you find an LED tha...   May 3 2020, 03:41 PM
FlacaProductions   I've ordered this from ebay - unfortunately, n...   May 4 2020, 10:11 AM
rjames   I just installed the 3rd brake light from Custom D...   May 18 2020, 11:11 AM
ValcoOscar   SSSSSHHHHHH :D :) Narp 914 3rd Brake light. Be...   May 19 2020, 09:49 AM
mgp4591   [quote name='ValcoOscar' date='May 19 ...   May 19 2020, 10:25 AM
ValcoOscar   [quote name='ValcoOscar' date='May 19...   May 19 2020, 10:38 AM
mb911   This is what I have and got it from @georgerud .....   May 19 2020, 10:00 AM
FlacaProductions   Straight to the rear glass - gotcha - just notch t...   May 19 2020, 10:49 AM
ValcoOscar   Straight to the rear glass - gotcha - just notch ...   May 19 2020, 10:57 AM
FlacaProductions   Hey @ValcoOscar - correct. I wasn't talking...   May 25 2020, 11:22 AM
GeorgeRud   That piece will fit into an opening cut into the u...   Jul 19 2020, 07:55 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:42 AM
