How to remove headlights? |
andreic |
May 1 2020, 07:47 PM
Member Group: Members Posts: 172 Joined: 21-December 15 From: Madison, WI Member No.: 19,479 Region Association: Upper MidWest |
Hello,
I ordered a couple of days ago the LED H4 headlights for my 1972 914. Unfortunately, today when I tried to remove the silver ring holding the glass housing, none of the 3 screws would move at all. Their heads are somewhat rusted, and the screwdriver stripped them right away. (I did put WD-40 before on the screws, and used the right size screwdriver, even used some valve grinding compound... no luck.) What should I do at this point? Can the screws be drilled out without damaging the unit badly? I would be happy to drill them out slightly bigger, and to put some screws with nuts on the other side, but not sure this idea would work. Thanks! Andrei. |
76-914 |
May 1 2020, 08:07 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
IIRC, 914rubber is selling those screws in SS. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 1st June 2024 - 05:27 AM |
